A few questions on changing trans oil. - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
This is a discussion on A few questions on changing trans oil. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Okay gotcha. Thank you For the help. Now to see how much oil I need and what kind I should ...
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    Okay gotcha. Thank you For the help. Now to see how much oil I need and what kind I should use.
    Jan 2012
    New Jersey
    2007 - Current STi:
    6 Speed Transmission And Rear Diff - 6 Liters Extra-S
    6 Speed Transmission - 5 Liters Extra-S
    42AutoSports
    CFLip2x 2012 WRB WRX Build
    Nov 2011
    North Jersey
    Quote Originally Posted by cflip2x View Post
    2007 - Current STi:
    42AutoSports
    Hold on, So 6 liters for the trans AND rear diff? so I'm guessing trans holds 5, diff holds 1? I'm really sorry to be such a pain and keep asking such novice questions, but I wanna make sure this is done right and I learn correctly.
  5. #19
    May 2010
    Pittsburgh, PA
    Just to add to the confusion.. I thought it was in quarts. 4 or 5 for transmission and 1 for the rear diff.
    For me it wasn't too critical. I ended up with a 5g jug when I folded the numbers out.
    Sent from my Galaxy Nexus using Tapatalk 4 Beta
    2011 STi Build Log
  6. #20
    Jan 2012
    New Jersey
    I believe its 3.6 quarts for the WRX and .8 for the rear diff so safely order 5
    for the STI it you would need around 4.3 quarts
  7. #21
    Nov 2011
    North Jersey
    Appreciate the help. Thank you.
    EDIT*
    One more question! So this covers the trans fluid change. I'm going to go ahead and change the diff fluid too. If I'm changing the rear diff fluid...shouldn't I also change the front diff fluid?? (hopefully that wasn't a realllly stupid question, but I'm assuming theres a fron't diff since its AWD).
  8. #22
            MainFrame's Avatar
    Austin, TX
    Front diff is in the transmission and shares the fluid..
  9. #23
    Nov 2011
    North Jersey
    Ahh, knew I was an idiot.
  10. #24
    Registered User wrx650's Avatar
    Feb 2012
    Cleveland, OH
    I wanted to go with extra s, but I couldn't find any local dealers that sold it. I went with redline products (75-90 ns for the trans and 75-90 for the rear diff). I found a t-70 bit at autozone and I got one of those snakey hose on a funnel things to fill it up. I haven't had any issues with those fluids. Wear some heavy duty rubber gloves so the fluid doesn't get it on your hands. It stinks like crazy and your hands will smell for a while no matter what you use to clean them.
    -Noah
    2009 Spark Silver Metallic Sedan - Stage 2+
    Stink-Eye Mob #91
    Help Me with My Build Thread : http://www.clubwrx.net/forums/builds...wrx-sedan.html
  11. #25
    Jan 2012
    New Jersey
    The clear tube I got was 5/8 x 1/2 x 20. It was easy enough to feed the tube into the dip stick hole but for you it might e easier to get to the full hole if you take off the intercooler.
    The oil does smell but as long as your careful its easy enough to clean up. I had some regular Nitrile gloves when doing the change. Also the oil runs a lot smoother so when you empty out the trans make sure to be aware.
    If you don't have a torque wrench and tend to over tighten you may want to get an extra crush washer or two. You can always pick up a torque wrench from harbor freight 10$ with a coupon.
