Flashing/Steady CEL and Sputtering, Also AP picks up PFFFF, PFFFE.... HELP!!! PLEASE! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on Flashing/Steady CEL and Sputtering, Also AP picks up PFFFF, PFFFE.... HELP!!! PLEASE! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; If u unplug the maf sensor, any improvement?...
    May 2013
    Massachusetts
    May 2013
    Massachusetts
    If maf didnt help I'd do a fuel pressure test aswell. Both w/ and w/o fuel pressure regulator vacuum line off the intake.
    Registered User Bro2517's Avatar
    Aug 2012
    Pennsylvania
    I tried the MAF and cleaned it, unplugged it gets way worse. This weekend Im gonna go over the injectors and fuel system. Eventhough the injectors are new, better check em any way and pressure/voltage to them.
  6. #19
    If it gets worse when the MAF is unplugged I'd exclude the MAF as a problem.
  7. #20
    Aug 2012
    Pennsylvania
    Yep, I have and did the same with all coil packs. N the compression is still good. Also still not leaking oil, It's going somewhere, but not the ground or radiator.
