turbo problems?
Results 1 to 15 of 18
This is a discussion on turbo problems? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have a 2004 wrx my boost meter reads -.05 most of the time never goes higher then +1.0 is ...
    Registered User bluewrx04_'s Avatar
    May 2013
    turbo problems?
    i have a 2004 wrx my boost meter reads -.05 most of the time never goes higher then +1.0 is this normal or is there a possible problem? i have never owned a turbo before and i just got this car used any help will be great.
    1.0 bar is not abnormal.
    Jan 2012
    New Jersey
    Bar to PSI
    1 bar = 14.5037738 pounds per square inch
    CFLip2x 2012 WRB WRX Build
            MainFrame's Avatar
    Austin, TX
    Depending on what units you're talking about, that sounds normal.
    May 2013
    thank you very much
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    Does getting into boost put a smile on your face? personally, 1 PSI wouldn't, but 1 bar should.
    haha enjoy!
    May 2013
    well i looked at it today and noticed that it was reading at .05 at max but most of the time sets in the -zones which if i remember right is vacuum and not getting air from the turbo also seems to be alot of noise under the hood
    Search for a boost leak.
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    what kind of noise? does it have an aftermarket intake? thatll make quite a ruckus. we need more info/pics
    2013 wrx sedan(saving up for a 2015 STI)
    Previous faist cars: '05 Mustang GT '02 RSX-S, '91 SR20 240sx, '85 300zx turbo
    Palmyra, NJ
    Welcome to a turbo car. If you're not putting the engine under load to force air into it from the turbo, then the engine will just act like what it is: a large air pump. It's going to pull air in to the combustion chambers so that it can go kablooey, then spit exhaust out.
    May 2013
    even when im under heavy acc. it still maxes out at .05 dose have after market intake but the sound sounds more like a big truckers turbo when they are going down then road
    any idea where i should look first for a leak?
    Palmyra, NJ
    You just said it does max out at 1.0bar in your first post...
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Is the gauge in Bar or Megapascal? 0.1 Megapascal = 1 Bar.
    If the gauge is reading 0.5 Bar or 0.05 MPa this is 7 PSI and it is wastegate pressure. I'd be concerned that the car's ECU is limiting boost due to the allotted KCA being pulled due to knock. Do you have any way to datalog?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    May 2013
    sadly no way to data log it is mpa reading
    i don't here any knocking in the engine
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by bluewrx04_ View Post
    You won't hear it! But your knock sensor will. Bet your IAM dropped below 6 and you're in failsafe fueling.
    Where do you live?
    Facebook me here
