Oil in intercooler pipe/turbo seals/turbo model
Results 1 to 10 of 10
This is a discussion on Oil in intercooler pipe/turbo seals/turbo model within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys. I've got an issue with my '06 WRX. I've got the car with all the modifications, big intercooler, ...
    May 2013
    I've got the car with all the modifications, big intercooler, 1.4boost, 320~350HP, haven't got the slightest idea what's been done to it.
    It's eating up a lot of oil (1liter per 1200-2000Km).
    Checked the intercooler and it's showing small amounts of oil in the turbo pipes. Checked and replaced PCV valve. Cleaned it up, drove it during the day, and in the evening same oil in the pipes.
    I think the turbo shaft and/or the seals might be going out. I'm afraid my engine will start running on oil and blow up, so i'm looking to fix the turbo problem.
    The thing is, i don't know what kind of turbo i have on it. I know it's a IHI turbo, There's also S47D stamped on it, might be the model #, googled it but nothing.
    I hope someone can help me identify what it is so i can search for a rebuild kit or a replacement, and if i have to replace it i won't need a remap.
    Sorry for my spelling it's not my first language.
    Help!
            MainFrame's Avatar
    Austin, TX
    Pretty much every IHI turbo I've seen has the model number etched in the compressor housing next to the serial number..
    May 2013
    Can't take out, since i'm using the car to drive around. But i guess, that's what i'll have to do in the end.
    For some reason I think i got the VF34 on it, and i've heard there are no rebuild kit for them. Is that right?
            MainFrame's Avatar
    Austin, TX
    IHI turbos aren't commonly rebuilt. You can usually find them used on nasoic for $300-$400.
            MainFrame's Avatar
    Austin, TX
    For what it's worth, when I had an IHI turbo installed it was very easy to read the model number off the plate on the compressor housing without removing anything.
    May 2013
    Just took out the turbo (have to say it was one of the worst pain with the oil and coolant pipes, and putting it back on must be even harder).
    This is what i found:
    - There was oil in the compressor housing (not that much, i left it on it's side and started draining out)
    - Oil in the rubber air hose coming from the air filter (no liquid oil, only deposits on the walls)
    - It has very less side to side play in the turbo shaft, doesn't reach the housing sides.
    - But has loads of play in the shaft from back to front.
    Are those normal? or the turbo has gone south for the summer...(seems to me)
    It's a VF34, i heard there are no rebuild kits for them, right?
    Any suggestions for DIY on mounting it back, maybe with pics or video (a good one).
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    Sounds like the thrust bearings are bad and the journal bearings are wearing out. You will need a new turbo.
    May 2013
    Quote Originally Posted by SKI.WRX View Post
    i tought the vf34 is a ball bearing turbo, not journal bearing. i could also be wrong with those bearing names. please correct me
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by r3mu5 View Post
    Yes.. here's a pretty in depth thread covering the vf34, if you're interested.
    VF34: COMPLETE teardown and re-assembly. PICS!! - NASIOC
    And more info on a variety of IHI turbos..
    http://www.mrtperformance.com.au/VF30-or-VF34
    Jun 2010
    Colorado
    Sorry for the mis-information, had just been reading about the Mitsubishi journal bearing turbos.
