wastegate actuator gone bad?
Results 1 to 11 of 11
This is a discussion on wastegate actuator gone bad? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've been having over boost issues on my 07 wrx. stage 1 cat back exhaust. ive been reading 17.xx psi ...
    Jun 2012
    nj
    I've been having over boost issues on my 07 wrx. stage 1 cat back exhaust. ive been reading 17.xx psi and started looking for leaks in the hoses and couldn't find any. I tested the solenoid and it works. I took out the wastegate actuator and tied fifteen pounds to it and lifted it up and it barely open. also the wastegate itself seems free and not stuck. is it safe to say i need a new actuator? input would be greatly appreciated.
    Palmyra, NJ
    What are you reading the boost pressure with? Gauge? Logging?
    What are you tuned with? Any other mods besides CBE?
    Jun 2012
    nj
    reading it with AP with their ots stage 1 map. no other mods
    Jun 2012
    nj
    anyone els??
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by njandy View Post
    That is not the correct way to test. You test it by applying 7-10 psi to the actuator reference port. The actuator uses positive manifold pressure to help open it. If you are seeing to much boost then use the LWG map.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    Jun 2012
    nj
    I looked already and Cobb dosnt have one for my car. I'll have to hook it up to my air compressor with a regulator than.
    Da boonies,Va
    Then email Cobb. You paid all that money for technical support,might as well use it.
    2002 FORESTER S
    1998 FORESTER S
    Jun 2012
    nj
    i went around the loop with them already sent logs and all that they say it's not a map issue. my customer support experience with them is not very good
    Jan 2012
    Philly Area
    In what driving circumstances are you seeing 17+? Also, what's Cobb's target boost for your car?
    Edit: Google is my friend, it's 14.7
    - Will
    Jun 2012
    nj
    I hit 17 pounds when I realy throttle it. they say 13.5
    Jun 2012
    nj
    hooked up compressor with regulator. set it at 13 psi and it barely moved. also sprayed soapy water on it and got plenty of bubbles. found my air leak so I need to hunt down a new actuator.
