Left Front Bearings
Results 1 to 4 of 4
This is a discussion on Left Front Bearings within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey guys I just got a 2006 Subaru WRX and the left front bearing is starting to whobble (but no ...
    Apr 2013
    Left Front Bearings
    hey guys I just got a 2006 Subaru WRX and the left front bearing is starting to whobble (but no noise). Is this like a common thing and how much is it to get a it fixed?
    Moderator Donkey's Avatar
    Da boonies,Va
    How do you know there is an issue? Yes,parts go bad. You didn't even state the mileage. Price is not fixed. Call your local shops for quotes.
    2002 FORESTER S
    1998 FORESTER S
    Palmyra, NJ
    How do you know it's a bearing? I'd suspect something wobbling would be more of a tire balancing issue.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Notice any change in the brakes? If the wheel bearing really has play, then the brake rotor "wobbles" with the wheel. Makes for a longer brake pedal move, if not even the need to pump the brake. Unless you notice a change in the brake, there is no bearing issue. Could be loose nuts, out-of-balance, damaged tire, even bent rim.
