HELP! High Idle After Cleaning Throttle Body!
Results 1 to 13 of 13
This is a discussion on HELP! High Idle After Cleaning Throttle Body! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So i took my TB off today and cleaned it and after putting everything back together the car is idling ...
    Registered User INTA:LECT's Avatar
    Jan 2010
    Colorado Springs
    So i took my TB off today and cleaned it and after putting everything back together the car is idling at 1500-1800rpm and the check engine light is on... I'm worried about driving it so i didn't take it to autozone to have the code read.
    Anybody have any idea what could be causing this?
    The car is a 2007 WRX TR.
    2007 Obsidian Black Pearl WRX TR
    3" Catless TBE, Protune, Tein Springs, TurboXs MBC, Apexi Turbo Timer.
    HawkEye Alliance #187
    Vote for my group UNTAM3D's new single "Gotta Go" to get rotation on 96.1 FM Radio!
    VOTE FOR US NOW!
    Jan 2005
    Eh, whaaaaa?
    Leak, probably. I'm betting you didn't change the gasket like you should have.
    You'll need a new one if you didn't: 16175AA243
    It's either a leak, or the valve is stuck open a bit. How did you go about cleaning it?
    Cody
    Jan 2010
    Colorado Springs
    Quote Originally Posted by Anub1s View Post
    I took the TB off, sprayed the inside with TB cleaner and wiped it down with a soft microfiber cloth. Re-installed.
    I forgot to include that my boost gauge is reading -20 into the vacuum side.
    Vacuum leak maybe?
    VOTE FOR US NOW!
    Moderator Donkey's Avatar
    Da boonies,Va
    20 inHg is what it should be. Just FYI,you don't have to remove the TB to clean it. Try resetting your ECU and see if that helps. But honestly the DTC would tell you exactly what the problem is. Are you sure you plugged the TB harness back in all the way?
    2002 FORESTER S
    1998 FORESTER S
    Jan 2010
    Colorado Springs
    I checked and double checked and it is plugged in all the way. I started it to let it warm up and it's idling normal now but the check engine light is still on.
    VOTE FOR US NOW!
    Aug 2012
    Tucson, AZ
    after cleaning your throttle body its going to idle high for a while. the ecu will reset itself after the zero point calibration is set. just to be sure though check hoses and lines around that area that may have been left off or knocked off
    Aug 2012
    Tucson, AZ
    the CEL will be on until your clear the code too. Some codes will reset itself, some won't. a vacuum hose normally wouldn't set off the CEL though.
    just by chance you didn't disconnect your MAF sensor and then forget to plug it back in before starting it did you?
    Jan 2010
    Colorado Springs
    Quote Originally Posted by nsibanez View Post
    Naw, didn't touch the maf. Car seems to be fine now other than the fans not wanting to kick on for more than a few seconds at a time. I doubt that's related tho. I just had my radiator replaced and I don't think they reset the ecu.
    VOTE FOR US NOW!
    Registered User AFP520's Avatar
    Aug 2005
    NJ
    Quote Originally Posted by INTA:LECT View Post
    Take off negative terminal on battery for about an hour and that should clear any ECU problems. The fans not staying on sounds like your new radiator is just flowing well.
    '14 SWP STI
    Palmyra, NJ
    Quote Originally Posted by AFP520 View Post
    Or pop the neg. terminal and pump the brakes for about 20-30 seconds and reconnect. Does the same thing in a lot less time
    Oct 2011
    Santa Ana, CA
    Check the tension on the cruise control/throttle cable. Too tight+heat will cause it to idle high.
    Da boonies,Va
    Quote Originally Posted by UEDan View Post
    He has a Drive By Wire throttlebody.
    2002 FORESTER S
    1998 FORESTER S
    Oct 2011
    Santa Ana, CA
    Woops. Nevermind. Too much tech for me here. Laters!
