Cobb access port trouble code PO244 how can I prevent from getting this code again
Results 1 to 8 of 8
This is a discussion on Cobb access port trouble code PO244 how can I prevent from getting this code again within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Sent from my SGH-T889 using Tapatalk 2...
    Registered User darinhollibaugh's Avatar
    Apr 2013
    seattle
    May 2007
    orlando flawduh
    what are your modifications? what were you doing when the code popped up?
    that is a CEL for overboosting
    desiree
    Apr 2013
    seattle
    just cool air intake it was shifting from 3rd to 4th gear and I was probably around 6000 rpm both times it happened to me the temperature of the outside air has been around 39 degrees does that have anything to do with it and what can I add to quit making this happen
    Moderator Donkey's Avatar
    Da boonies,Va
    A professional tune might fix it. It is an overboost code.
    2002 FORESTER S
    1998 FORESTER S
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    What intake do you have, and what Cobb tune are you using? Are you sure the tune is compatible with your intake?
    Cobb also provides LWG maps if your boost consistently exceeds map targets.
    2007 Outback 3.0R wagon
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    You overboosted. Check to make sure you are running the right map. You can also do what Rambo said and switch to the LWG map that Cobb offers.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    Apr 2013
    seattle
    Im all ready running a LWG map with the cob cold air intake
    Oct 2010
    Portland, OR
    If the intake is your only modification, and the LWG map isn't helping, I would give Cobb a call then. You also ought to pull datalogs for analysis.
