2003 WRX - P0420 Code and Exhaust Noise After MAF Replacement
Results 1 to 5 of 5
This is a discussion on 2003 WRX - P0420 Code and Exhaust Noise After MAF Replacement within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi guys, I've got a 2003 WRX with 92K miles and a 100% stock exhaust system. I had my vehicle ...
    Feb 2008
    Hi guys,
    I've got a 2003 WRX with 92K miles and a 100% stock exhaust system. I had my vehicle diagnosed by a shop after it deadlined on the highway recently. The shop told me my MAF failed and replaced it. After getting the car back I noticed that the vehicle sounds louder at idle, but it is not idling high. After driving about 10-15 miles I got the Cat Converter efficiency code (P0420). I cleared it only to have it return 50 miles later.
    Any suggestions on how to approach this? I've performed a visual inspection of the exhaust system and from the external view nothing appears to be incorrectly installed/missing. Do I need to pull the MAF out and inspect it?
    Thanks!
    I don't think the MAF would be giving you a PO420 frankly. Best bet is to take it back to the shop at this point. I'd check the wiring to the O2 sensor for a short, fault, or disconnected clip first though.
    Feb 2008
    Ok, sounds like a good place to start. In your experience, can a missing/damaged/failing 02 sensor cause an increase in exhaust noise? I would almost think there would have to be a corrosion hole, failing, or incorrectly installed seal to cause that.
    Yes a hole or leak would do it.
    Moderator Donkey's Avatar
    Da boonies,Va
    The P0420 code is for the rear o2 sensor. Free flowing exhaust with no mechanical DTC fix or engine management will cause the code as will a failing sensor or leaky exhaust.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
