ploom of blue smoke
Results 1 to 5 of 5
This is a discussion on ploom of blue smoke within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so everytime I let my car set for a minute, when I start it I get a ploom of blue ...
    Apr 2012
    A, A
    ploom of blue smoke
    so everytime I let my car set for a minute, when I start it I get a ploom of blue smoke from the tail pipe. The engine is an ej22 with 15000 on it. So I doubt its the rings. I ran my car without oil so im in the process of pulling the motor due to a high end knock. So that being said Im trying to do as little work as possible. I think its a rod or a valve. So I was wondering if the bloushe 18g turbo could be letting oil get by and burned in the exhaust? Or am I just reaching in the dark?
    Jun 2012
    nj
    Red face
    sounds like rings to me. what about letting it sit while idling?
            MainFrame's Avatar
    Austin, TX
    Blue smoke is usually an indication that your engine and/or turbo is burning oil. Where that oil is coming from is anyone's guess.
    Jan 2012
    Philly Area
    Plume. /sorrymyfathereditsforalivingandican'thelpitnow
    - Will
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Blue smoke = not good.
    Man, if you're already pulling the engine, just do it right! Do a compression check, leak-down check. Pull the heads, just spend the money for the head gaskets. You ran engine w/o oil? Well, could easily be pistons. Valves probably have a looonger tolerance to no-oil. Replace bearings as indicated by wear (i.e. if there is = replace). Do what it takes to be done right. Nothing worse than having a halfassed engine and pulling it again. You might as well do a complete job first time.
