Stock o2 sensor on aftermarket downpipe - extension?
Results 1 to 15 of 15
This is a discussion on Stock o2 sensor on aftermarket downpipe - extension? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Anyone ever run into an issue with the stock o2 sensor not reaching the post cat bung on an aftermarket ...
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Anyone ever run into an issue with the stock o2 sensor not reaching the post cat bung on an aftermarket downpipe? There are two spots and I know the WBO2 sensor needs to be before the cat. I have been told the stock o2 sensor goes in the bung behind the cat. I see the bung there, but the stock o2 senor does not have long enough wiring to reach. It is about a foot short. Anyone else run into this before?
    Thanks,
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    What downpipe are you using?
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    Palmyra, NJ
    Weird...most aftermarket DPs have the stock O2 bung in a similar location to the stock DP.
    Post pics.
    Nov 2012
    I've got the turboxs down pipe (catted) for the 2011 STI sedan.
    Nov 2012
    Post pics.
    yeah the cat on my downpipe is much further back than the stock. The stock downpipe, there is pretty much about 8-9 inches between the turbo and the cat, but on the turboxs, there is a good three feet from the turbo to the cat.
    Link - http://turboxs.com/shop/08-10-subaru...-downpipe.html
            MainFrame's Avatar
    Austin, TX
    I had trouble getting the old one out of stock exhaust one time, so I just ran down to the auto parts store and bought a drain plug and some high temp lock tight and screwed that into the hole. Problem solved.
    Nov 2012
    Well the o2 sensor came off fine. The second bung is plugged already. So did you just not hook up the stock o2 sensor?
    Mar 2012
    Palm Beach, FL
    Looks like you need to use the bung in front of the cat for you stock sensor.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
            MainFrame's Avatar
    Austin, TX
    Nope, no reason to use it. It's only function is to throw a CEL.. which will be disabled in your tune anyways.
    On my personal car I have my WBO2 sensor installed in that bung, of course I am also catless.
    Aug 2012
    Alexandria, VA
    Interesting, my tune from Torque Performance has this in their instructions:
    Stage 2+ customers. Do not use any mechanical CEL Fix on the rear O2 sensor. This includes any spacer that takes the rear O2 sensor out of the exhaust stream. They are unneeded and may lead to other issues. CEL’s are not normal for these maps and if they occur they should be looked at and taken seriously to determine a cause.
    Sounds like you really need to find a extension or way to get the O2 sensor inserted for your tune to operate properly. I know a Stage 2 tune does turn off some of the O2 sensor readings but more than likely not all of them.
    Unfortunately, Robin, that's only an option for 16-bit ECUs. The rear O2 sensor is used for fueling calculations in the 32-bit ECUs. They must have a working rear O2 sensor...
    Resident Tuner @ WTF Tuning
    Moderator Donkey's Avatar
    Da boonies,Va
    I would contact Turbo XS about the issue.
    2002 FORESTER S
    1998 FORESTER S
            MainFrame's Avatar
    Austin, TX
    Hmm.. I thought that was just for STis... so all 32-bit ECUs use the rear O2 for closed loop corrections?
    Da boonies,Va
    Yup.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    Nov 2012
    Talked with Turboxs. Perfect world I would have the stock o2 sensor put in the bung behind the cat and the wbo2 sensor in the bung before the cat (which I knew had to be the case with the WBo2), although he told me that there wouldn't be a huge difference if it was vica versa. So I am going to look into seeing if I can free up some wiring coming back from the harness and if not then I will add some legth to the stock wiring. I would rather have the wbo2 before the cat and the stock o2 after. Thanks for the input everyone!
