Boost Spike to NO Boost, HELP
Results 1 to 15 of 26
This is a discussion on Boost Spike to NO Boost, HELP within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; alright i have a 05 wrx with equal length headers, catless up pipe and down pipe. about 95k on the ...
    Mar 2013
    alright i have a 05 wrx with equal length headers, catless up pipe and down pipe. about 95k on the car and just recently in ANY gear you step on it and it will spool real quick and spike up to about 19psi which is no good, and then immediately go down to about 3-5psi then SLOWLY creep up if move at all. i checked all vaccum lines and clamps to and from the intercooler and nothing seems loose nor can i hear a hissing. Now there are several things i had in mind. 1. could it be the wastegate actuator getting a weak diaphram? 2. could the boost solenoid be failing?3. is it the turbo.
    if anyone could help with some ideas i would be very thankful
    Thanks, Kyle
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Since there are no other responses so far: check the forum for wastegate actuator arm. There have been several threads with issues about that. Something with the spring needing tightened or replaced... Don't have a real good recollection, though....
    Moderator Donkey's Avatar
    Da boonies,Va
    Is the car tuned for the mods you have on it? Are you seeing a check engine light at all? Datalog the car and post it up.
    2002 FORESTER S
    1998 FORESTER S
    Mar 2013
    Quote Originally Posted by Ingo View Post
    thanks for response, i did check the waste gate by putting compresses air too itand it did hold.
    yeah i have h cobb ap2 and its tunes to stage 2. no CEL is on. i do have a small crack in the equal length headers right at the junction. could this be enough of a leak to cause a pre boost leak?
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Straube63 View Post
    OTS Cobb maps are for use with stock exhaust manifold ONLY. So that's one problem.. the fact that they are cracked is another.
    Da boonies,Va
    If you have the AP then datalog the car.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    Mar 2013
    i will data log once i go to lunch today.
    I know that the cobb stage 2 map is for stock header and whatnot but it shouldnt really affect the turbo that much, the fact is that it ran perfectly fine up to this point. i started to notice a slight exhaust leak and then the boost problem started happening.
    if i gradually build boost, it will hold at about 10psi then slowly creep up.
    im beggining to think that the slight crack in the header is the culprate. though i will get a datalog for you guys here shortly.
    Thanks again for the help
    Palmyra, NJ
    yeah you should be tuned specifically for those headers; not just an OTS Stg 2 tune...but I suspect a crack in headers really could cause a problem as well.
    Mar 2013
    once i fugure out what is going on im going to get it tuned on a dyno. the thing is that something had to let go, because it help a solid 15 psi for quite a while
    Mar 2013
    Another update is that when its cold it doesn't do it at all and when it's hot is when Acts up
    Mar 2013
    what should i be datalogging? on cobb does it only log what you select or if you hit okay to data log say learning a/fr does it just log that or everything in the live data list?
    Palmyra, NJ
    Metal expands as it heats up...crack in headers also expands...just saying.
    Mar 2013
    well then in that case wouldnt the crack be more evident when its cold then because the crack would be further apart then once it heats up it will close the gap?
    also i just got a custom map from clarktuning so im going to re flash that to the car, then ill data log. then post it. thanks guys
            MainFrame's Avatar
    Austin, TX
    So you fixed the header crack?
    Mar 2013
    Okay so here is the datalog with the clark map. the boost readings are all over the place. but also the a/f learning seems odd.
    https://docs.google.com/spreadsheet/...Hc&usp=sharing
    FIXED^^
