Headlight still won't work
Results 1 to 2 of 2
This is a discussion on Headlight still won't work within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So i replaced my HID H1 lowbeam headlight because it was out. Checked to see if it was working and ...
    May 2012
    So i replaced my HID H1 lowbeam headlight because it was out. Checked to see if it was working and it still wasn't. I re-did the install and it still didn't work. Even though the fuse wasn't blown, I still replaced it with no luck. I have a replacement ballast on the way and if that doesn't work, I'm pretty screwed. Unless you guys had similar experiences/suggestions.
    Aug 2012
    Tucson, AZ
    it's more then likely the ballast. its your amplifier
    either that or the polarity was changed and in that case just swap the connectors around
