Data Log Question, Possible Knock High Rpm
Results 1 to 4 of 4
This is a discussion on Data Log Question, Possible Knock High Rpm within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok, so I decided to fool around with data logging before I get into more serious modifications. I would like ...
    Registered User Kwrxp's Avatar
    Aug 2012
    Spring Grove, PA
    Ok, so I decided to fool around with data logging before I get into more serious modifications. I would like to understand what the logs show and how to log "better." Anyway, I ran two quick ones this evening, and everything looked alright, except, it looks like I have some FLKC at red line. From what I have read, anything above a "2" is worry some, along with FLKC at high RPM. It seems to happen at ~6500 RPM and it is always -1.41. Now, I understand that FLKC can occur when "noise" gets loud. I.E. road vibrations, debris bouncing off the block, etc. After trying to figure out where it is coming from, with my very limited knowledge, I think it may be from my not-so-smooth release of the accelerator. It seems to happen every time I let out the throttle and bump it slightly (31%-41%-36% & 32%-36%-32%).
    I know my logs are not as complete as they should be, I am missing knock sum and total ignition timing, and may have somethings that are not so important. Still learning and all.
    Besides the FLKC, I think it looks alright, then again I am still very green when it comes to this. So, any input and advice would be greatly appreciated.
    Also, I saw a random spike in A/F on log 1. Jumps from a .88 to an 11.38 to a -1.12, it is not in log two, so possible fluke?
    Also, also... 3rd gear pull.
    Thanks,
    Spencer
    https://docs.google.com/spreadsheet/...RSTU5bHc#gid=0
    https://docs.google.com/spreadsheet/...0TmZ5eVE#gid=0
    Oh, also, I have been using "Romraider's How to: Make useful data logs" and Donkey's "Data logging with Romraider" thread. Any other suggestions or learning material would be great!
    '11 WRX DGM
    Moderator Donkey's Avatar
    Da boonies,Va
    Need to know mods and octane used.
    2002 FORESTER S
    1998 FORESTER S
    Aug 2012
    Spring Grove, PA
    Sorry, straight up stock (spt exhaust), using 93. Just trying to understand logs before I start doing anything serious. Just so happened to notice the flkc.
    '11 WRX DGM
    Da boonies,Va
    In the "how to" section on Romraider there is in on "how to read datalogs". The hardest part about reading datalogs is being able to differentiate between a mechanical issue and a tuning issue.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
