2011 Headlight issue after Cobb AP install
Results 1 to 15 of 17
This is a discussion on 2011 Headlight issue after Cobb AP install within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Don't know if anyone has posted about this issue so if there an existing post please help me. I just ...
    Registered User sillyGhost's Avatar
    Apr 2013
    WI
    I just received my Cobb AP (SUB-003) yesterday and installed it. I currently have a Cobb SF Intake w/ Box as the only modification on my 2011 WRX. I installed the Stage1 93 Octane Normal Wastegate Rev. #3.10. After it successfully installed, I noticed an issue. My headlights stayed on after I turned the car off and take the keys out of the ignition. As I remember, they always shut off automatically once I turn the car off. Other than this issue, the MAP install works great and I definitely can say it corrected the boost delay I had before the install. Please help!!!
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    That is strange. Maybe a relay issue?
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Moderator Donkey's Avatar
    Da boonies,Va
    I can't see this being an AP issue. I agree with a sticking relay.
    2002 FORESTER S
    1998 FORESTER S
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Do you install the Cobb SFI yesterday, too?
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
            MainFrame's Avatar
    Austin, TX
    accidentally flipped the parking light switch?
    Apr 2013
    WI
    How do I go about checking if it's sticking or not? Sorry, I'm still a noob.
    2011 WRB WRX Premium Sedan
    1998 RBP RS Coupe
    Apr 2013
    WI
    Haven't looked at that yet but I'll check that after class. Thx
    1998 RBP RS Coupe
    Apr 2013
    WI
    Quote Originally Posted by lokey View Post
    No, I bought the car a month ago with it installed.
    1998 RBP RS Coupe
    Palmyra, NJ
    Stage 2 headlights?
    Apr 2013
    WI
    Stage 2 headlights?
    I'm not sure what you're trying to say. Do you mean to install the Stage 2 MAP?
    1998 RBP RS Coupe
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by sillyGhost View Post
    Mikie was just being funny.
    2007 Outback 3.0R wagon
    Da boonies,Va
    A relay is a relay. Doesn't matter what it is used on. Car,machine,industrial,home,electronics. If you know how a relay works it's pretty easy to troubleshoot.
    Relays
    Obviously if the "switch" wire is not energized and the component the relay controls is still operational,this would be considered a "sticking relay" as it is stuck in position allowing voltage to pass through. Though some do use the ground as the "switch" wire. Subaru does do this sometimes. So you need a schematic for the headlight wiring to know which wire to check. Or you can just spend $5-10 and swap the relay with a new one. Should be a SPST.
    2002 FORESTER S
    1998 FORESTER S
    Jan 2011
    Crofton, MD
    Warranty.
    Greg
    Build Thread
    May 2010
    Pittsburgh, PA
    I'd take that sucker back to the dealer. It is a bit different than the older subies, however.
    Correct behavior (to my understanding):
    -If car is on with headlights on, and you shut off and take key out, lights go off regardless of your control (I believe yours is not following this)
    -If car is off with headlights on and key out, you can turn the headlights on and off (different than older models to my understanding)
    2011 STi Build Log
    Aug 2010
    Yonkers/NYC
    Also, if it is the DRLs you are talking about ,pull the E brake & they go off. If the E brake is released they stay on.
    T0ny
    2011 WRX
    2012 FXT
