No Positive Boost
Results 1 to 4 of 4
This is a discussion on No Positive Boost within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey all, I just picked up an 2003 WRX sedan this weekend, and everything was going fine with it until ...
    Apr 2013
    No Positive Boost
    Hey all,
    I just picked up an 2003 WRX sedan this weekend, and everything was going fine with it until today. I did an intake snorkus delete in the right fender this morning, and took the car out for a drive. It was boosting just fine. I then gave my buddy a ride, I got on it through third, and suddenly lost all boost pressure above 0. We pulled the battery cables, same problem. The car isn't leaking any oil or anything. I've heard that it could be that the stock up pipe cat can deteriorate and jam into the turbo, causing a lack of boost. Also, the car is stock as far as I know except for the intake snorkus delete. Unfortunately, I have work and school for the next three days until midnight, so I cannot have it looked at until Wednesday 4/3. If anyone has any knowledge or has experienced this, please help! Thank you!
    -Justin
    May 2010
    Pittsburgh, PA
    boost pressure above 0? What are you gauging this off? Do you have a boost gauge or are you logging from the ECU?
    You should be hitting at least 7psi no matter what due to the wastegate actuator having a 7psi spring in it. Do you have the stock turbo? Any other modifications done to the car?
    EDIT: Also, just to clarify, we are speaking psi relative to atmospheric, correct?
    2011 STi Build Log
    Apr 2013
    I have a factory boost gauge, even under full throttle, I am at 0 boost, and you can't feel any kind of boost. It's as if someone took my turbo out, but the car runs just fine otherwise. The turbo is stock and I have no modifications besides the air box snorkus delete.
    I am talking in terms of atm. I start at around -0.5, and and full throttle will only rise to 0
    Jan 2005
    Eh, whaaaaa?
    Semantically speaking, there is only positive boost, there is no negative. That is called vacuum, so you just have no boost.
    Mechanically speaking, I'm betting the charge piping came off somewhere. Check that the intercooler is properly seated and the pipe couplings are securely fastened.
    Cody
