HELP wrx mechanic - Page 2
Results 16 to 30 of 39
This is a discussion on HELP wrx mechanic within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; The videos are up...
    Mar 2013
    Odessa Texas 79764
    The videos are up
    Palmyra, NJ
    Videos are up in mobile format. Remove the M. in the link and it still isn't working.
    I'm willing to bet you shredded second gear though...
    Mar 2013
    Odessa Texas 79764
    Go to YouTube and type my name I guess it might work? Berny Arredondo I have two videos
    http://youtube.com/channel/UC2vWKq8n...?feature=guide
  6. #19
    Palmyra, NJ
    Ouch that doesn't sound good!
  7. #20
    Mar 2013
    Odessa Texas 79764
    What do you think it is? Bent valve piston rod?
  8. #21
    Palmyra, NJ
    Sounds like a valve rattling around in there honestly...but internal knowledge of that is a little further beyond me.
  9. #22
    Mar 2013
    Odessa Texas 79764
    But what I wondering is why don't any check engine lights come on
  10. #23
    Oct 2005
    Late Devonian
    ^That is a curious fact. Apparently whatever happened isn't causing any issue that shows up on any of the sensors.
    I agree with Mikie but it is really hard to tell for sure. You could check the timing without tearing the motor down, but I kind of would of thought it would throw a misfire code if it was far enough out to have the valves interfering with the piston. I'd have someone listen/look in person first, but you can pretty much count on the motor coming out and getting torn down before that is cured and you definitely shouldn't run/drive it any more if you want to try to reuse any of that motor.
  11. #24
    Mar 2013
    Odessa Texas 79764
    Also another question my oil got supposably changed a week ago and Friday I check it and there was no oil can oil burn that fast my car dose not leak oil at all I check the oil pan no leak at all I told my dealer that they didn't change the oil because I had no oil left !
  12. #25
    Registered User wrx1234's Avatar
    Sep 2009
    Dover DE
    well someone needs a new engine. I wouldn't start it again.
    2009 WRX - Catted DP, Torqued performance stage 2
    2011 Sportwagon TDi
    1970 Chevy Impala Convertible 454
  13. #26
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    Quote Originally Posted by Wrxberny View Post
    Did the dealer do the oil change?
  14. #27
    Mar 2013
    Odessa Texas 79764
    And where I live I can't find anybody that knows how to work on these cars due to the motor I also heard that the pistons are the weakest part of this motors is that true?
  15. #28
    Mar 2013
    Odessa Texas 79764
    Yeah they said they did I didn't check didn't have time!
  16. #29
    Oct 2005
    Late Devonian
    Is there oil in the coolant?
    You only have 30K on the car? It is a bit of a moral dilemma, when you did blow the shift, but if there actually isn't any oil in there you were doomed anyway. I kind of think a dealer tow to confirm the presence of oil in there (it could be down off the stick but not that low really) would be reasonable. If it is just a bit low I'd say it is on you, but otherwise I wouldn't feel too bad suggesting that it is on them to tear it down and see if what failed could be contributed to low oil levels. Really it is pretty much on them to fix it anyway if they didn't put any oil in.
  17. #30
    Dec 2012
    South Jersey
    Someone forget to tighten the drain plug? Happened to a friend and the dealer ended up giving them a new car. It was the first oil change iirc
