Weird Clunk Noise When Start Up And At Low Idle.
Results 1 to 11 of 11
This is a discussion on Weird Clunk Noise When Start Up And At Low Idle. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2002 subaru wrx, 110k miles, grimspeed control, 50/50 BOV, headers, cold air, it makes a weird clunking ...
    Mar 2013
    I have a 2002 subaru wrx, 110k miles, grimspeed control, 50/50 BOV, headers, cold air, it makes a weird clunking noise at start up, and than at higher rpm it isn't there. Than at idle I can hear the clunking noise as well, but sometimes i cannot. I can only hear it when I am in the car, when I pop the hood to try and find it, I cannot locate the sound at all. I have read the forum and have read many reasons, But some say it can be the starter? I have had an issue with the starter sometimes grinding but not often. Also, some say it can be a piston slap, but would you hear that out of the car? Also, when I turn the car off, it makes the clunking noise before dying. Any suggestions or comments would be helpful. Thank you in advance. This is my first Subaru and my first time to this thread. Just paranoid about the whole sound.
    Palmyra, NJ
    Tune?
    You should take a picture of the noises so we can hear it.
    Mar 2013
    Tune?
    I will take a video of it when I get home and post the URL from YouTube since I cannot post videos yet. And it got tuned a week before I bought it. This morning it did it on the start up. But didn't do it at low idle.
    Mar 2013
    Here are the two videos of the noise my car is making. The first one is at start up, the second one is at idle. It does it while decelerating and not accelerating. Any help is appreciated.
    Mar 2013
    Palmyra, NJ
    that kind of a clunk I'm hearing sounds like there might be worn mounts or bushings...kind of what I'm dealing with in my car.
    I'd check your transmission mount, as well as rear differential bushings.
    Mar 2013
    Thanks. That's exactly what I am on my way to do too. Going to go throw it on my lift and check them out. And everything else. I will let you know what's going on.
    Mar 2013
    So I replaced the starter cause it sort of needed it. But the clunking was the inter cooler hitting the firewall, the screws on the mounts came loose, so I pulled the inter cooler down and tightened it up and the clunking went away. I hope you find out what's wrong with yours. Thanks for your help.
    Palmyra, NJ
    How about that. Good sleuthing!
    I'm almost positive my rear diff mount bushings and the rear subframe bushings are just toast. I have replacements for them, it's just a pain to get under there and replace them. The rear diff mount bushings might just be the most annoying thing to upgrade on a Subaru...the subframe bushings aren't hard...but it's also cold out and has been a ****ty winter. But...Spring is here!
    Jan 2014
    Check the starter mounting bolts for tightness. This is the most common reason for clunking/ grinding noise.
    Palmyra, NJ
    Quote Originally Posted by riyarobin View Post
    Almost a year old??? OP already fixed his issue??? I don't have that car anymore???
