A Reflection: DIY Timing Belt 2006 WRX - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 46
This is a discussion on A Reflection: DIY Timing Belt 2006 WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by wrx650 I enjoyed reading this (I lol'd at the victory pic) +1...
    slow no mo' ! Shoopster's Avatar
    Apr 2013
    Montreal
    Quote Originally Posted by wrx650 View Post
    +1
    -Stephanie 2004 WRB WRX | Blobeye Syndicate Member #104
    "I can't see the Shoopster from here; I'll wait for you outside."
    Shoopsterbuild 2.0: Better than it was before. Better, stronger, faster. And such JDM, yo.
    Hm you may be right. The factory manual specifies which. I remember having bolt threading problems though.
    Looking over this thread again, I should mention what I did to clear the power steering stuff and get the rad out: instead of disconnecting it, I just rotated it out of the way. Worked fine, no leaks then or now. Again I could have gotten lucky. Like Yeager said though I'd rather be lucky than good any day.
  6. #19
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Rotated what? The reservoir or the pump?
    I know they changed radiators between 2002 and 2006, I dunno if they changed the PS components as well, but there is no way the rad was getting passed the hose in place on my 06.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  7. #20
    The reservoir. There is no pressure on that side of the system and the hose rotated relatively easily yet remained clamped. No leaks. I was very careful but it worked.
  8. #21
    Registered User Cmcmenam's Avatar
    Dec 2014
    Kent, OH
    Any seals I should think about replacing? I am also using the gates kit with water pump. I plan to replace WP with factory metal gasket and do the Motorad Thermostat with included Gates gasket per your thread.
    my 2006 WRX has 120k miles and want this thing to last well into the 200k+
  9. #22
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by Cmcmenam View Post
    This thread is pretty old bit still has good info on it. With that said how much time/money do you have? I had mine done earlier this year and just had the tensioner, water pump and thermostat replaced but had the tech check the other idlers. If they were good leave them, which they were.
    If you have time and patience you might as well do the cam seals and front crank seal while your there
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
  10. #23
    I replaced all four cam seals and the crank seal.
    I used a Subaru thermostat and Subaru gaskets. The Gates WP failed after 60K and I am now using an Aisin.
    I replaced all the pulleys. Mind the bolt lengths, they pulley depth may have changed so make sure your bolts are the correct length to grab enough thread but not too long to go in too far or bottom out etc.
  11. #24
    Dec 2014
    Kent, OH
    Money is the thing...I would love to go above and beyond with this maintenance but after the Gates Kit, new hoses, new AC and Alt. belts, oil, antifreeze, etc... I'm about tapped. Also, I will be replacing all the pulleys with the new kit but maybe I look at different water pump since the gates failed after 60K
    How big of a pain are the cam and crank seals?
  12. #25
    I found them daunting. I was rescued by members here. I made a thread; search for it because I'm on my mobile. The trick is immobilizing the cam gears -- all at once -- while loosening a 10mm hex bolt from 80 ft lbs or so.
    The guys here helped me use the old belt and clamps to immobilize the cams. The thread has pictures, find it.
    We used an O-ring pick to remove the old seals. They fought back.
  13. #26
    Ok so if you have the correct cam and crank sprocket tools, use those. If not, buy those. If not still, try what I did but at your own risk:
    Cam seals, crank seal: Replacement? How?
  14. #27
    Jun 2006
    Nor Cal
    I compared my OEM water pump on my 2006 that came out with the Gates I put back in. Markings, castings, part numbers were identical. It could be that SD_GR bought his Gates kit when they were using a different style pump (his maintenance was done a few years before mine IIRC).
    He is correct the cam and crank seals are a bear. I bought all the seals just in case and inspected them, they all looked beautiful, so I left them alone.
    Don't forget to buy new hose clamps. The aftermarket hoses are thicker than stock so the factory clamps will not work.
    Also buy the crank pulley tool and the cam tool.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  15. #28
    Quote Originally Posted by 06wrx4me View Post
    I think you're right. The Gates pump and the Subaru pump it replaced differed in that one, I forget which, does not have an enclosed impeller.
    Gates was no more or less reliable than the OEM Subaru pump -- probably because that was a Gates also I suppose -- and I've had two pumps fail at 60K each, one OEM Subaru, one Gates.
    We'll see how the current Aisin goes.
    EDIT: Here:
    Gates Timing Belt Kit - My Impressions
    In the last post of that thread I took a picture of the Gates and the Subaru OEM water pumps side by side for comparison.
  16. #29
    Dec 2014
    Kent, OH
    Thanks guys! All great info. I'll see about checking the cam seals but prob just gonna stick to the timing belt. I don't need added trouble right now
  17. #30
    Aug 2012
    Tucson, AZ
    No do the water pump and idlers with it
    Previous cars:
    2009 WRX (sold )
    IG - kevinrimcoski
