Results 1 to 15 of 16
This is a discussion on Car wont fire..... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Car stalled out on me one nite and had to have it towed. 2004 wrx 2.0 invidia downpipe stage 2 ...
    Registered User Clark1989's Avatar
    Aug 2011
    Penn Run, Pennsylvania, United States
    Car wont fire.....
    Car stalled out on me one nite and had to have it towed. 2004 wrx 2.0 invidia downpipe stage 2 tune and turbo back exhaust and cobb sf intake. Changed fuel pump to a walboro 255 thinking it was fuel related car ran fine then stalled out the next morning at idle. Changed fuel filter in engine bay and ran fine then did same thing next morning. Drained all fuel changed filter under the hood again ran new 93 and now it wont fire
    2004 WRX Cobb SF
    TurboXs RFL Recirculating
    Invidia V2 DP SRS Catback 285hp 283ft lbs
    Jimmy
    Blobeye Syndicate #3553
    Oct 2011
    Santa Ana, CA
    Pull your plugs. Are you getting fuel? Clogged injectors?
    Fuel. Are you getting a spark. Coilpacks? Bad fuse?
    Aug 2011
    Definitely getting a steady stream of fuel and as for plugs and injectors i havent checked those yet. Would there be any CEL associated with bad plugs? Maybe crank or cam sensor possibly? But that would throw a CEL code if im not mistaken. At this point im very frustrated and would rather not take it to a garage to get bent over with diagnosing costs and labor....
    Nov 2009
    How old is the battery?
    Jan 2005
    Eh, whaaaaa?
    How well seated is the ground on your battery?
    Cody
    Aug 2011
    Well ground wire looks fine and my battery is a subaru battery and its only around 4 months old. Even had it hooked to my truck when i tried to start it
    2004 WRX Cobb SF
    Jimmy
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    If it turns over strong with the starter it's most likely NOT the battery or its connections. Anything else is still possible... Pull the plugs, are they wet? If you get no spark they should be soaked in gasoline. If they're dry your injectors are likely not firing (not opening...), check your fuses also.
    Mt. Laurel, NJ
    What about the fuel filter in the pump assembly in the tank? That has been known to get clogged over time...
    Aug 2011
    Ok update on car. Let it sit in a heated garage and it fired up. Why would it fire when warm but stall and just crank when cold?
    2004 WRX Cobb SF
    Jimmy
    Mt. Laurel, NJ
    Battery.
    Aug 2011
    Well car still wouldnt fire the other night even with it hooked up with jumpers to my truck
    2004 WRX Cobb SF
    Jimmy
    Jan 2005
    Eh, whaaaaa?
    So car turns over in cold or warm, won't start when cold. But will turn over and eventually run when it's warmed up? Could be fuel related, still.
    That is definitely typical bad battery behavior, although it usually rears it's head in the form of slow cranking; not cranking and lack of starting.
    Cody
    Mt. Laurel, NJ
    Valid point Code-man...
    Get a new wife.
    Aug 2011
    Unplugged the maf sensor and car started up fine. Plugged it back in and had same issues.
    2004 WRX Cobb SF
    Jimmy
    Mt. Laurel, NJ
    Get a new maf.
    See what I said up there?
