The tale of my brakes: a 2006 wrx's reflection on wear and replacement
Results 1 to 9 of 9
This is a discussion on The tale of my brakes: a 2006 wrx's reflection on wear and replacement within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I'm at 95k miles now and done a few brake changes on my car. FWIW, I don't autocross or ...
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    So I'm at 95k miles now and done a few brake changes on my car. FWIW, I don't autocross or track day this thing, I drive it spiritedly to and from work and sometimes to Vegas and other far off destinations.
    Some bullet points:
    * My brakes were not bled properly at the factory, pedal was spongy
    * I bled the brakes in the incorrect order the first two times, and found out it makes a difference on 3rd
    * Replace the rear pads in kind with the front pads
    * Replace the rear rotors
    It all started at around 30k when my front factory pads were done and had eaten the rotors with them. I inspected the rears, they looked great, so Off I went to buy parts. I bought a Stoptech branded front and rear kit with stainless lines all around, Axxis Ultimate pads and Brembo front cross drilled rotors. I installed the front rotors, pads and lines. Tried to install the rear lines, but the damn monkey at Subaru who installed every bolt on my car far too tight, struck again and foiled my plans. So to this day it rides on rear rubber lines. I flushed and bled the brakes the way I always have, (Brakes are brakes right?) and had the same spongy pedal I had before. "Huh must be normal" I thought to myself.
    Tip: Buy one of these, you'll like it Motiv brake bleeder gets my seal of approval
    The Axxis Ultimate pads, dust like no other. Now to be fair I have had big brake kits on other cars, ran most of the major pad choices, but the Axxis take the cake as the most self loathing pad. They dust like crazy and wear worse, without the benefit of a striking increase in braking ability of other choices. So at 50k miles the front Axxis were D-O-N-E.
    The Brembo cross drilled still looked fine, and the rear still had a considerable amount of life. I shrugged, and rolled on a set of PBR pads, flushed and bled the brakes (the wrong way again, Surprise same pedal feel!) and motored on down the road.
    At around 80k miles the PBR's were toast and the rears were getting close too. Front rotors were shot as well. Happy with the feel and wear of the PBR's, I bought another set of those for the front, a new set of stock replacement front rotors (thought I was gonna sell the car why put on cross drilleds?) and remembered I had the Axxis ultimates from 5 years ago sitting on a shelf for the rears. Now about this time I was convinced something was amiss with my pedal feel. During hard stops it felt like the rears were doing very little and the pedal was spongy. It was then I RTFM'd and discovered my bleeding sequence had been all wrong....facepalm.
    I set about changing the brakes, no big deal here, and tried to change those rear lines again.....no luck....goddamned Subaru monkey. Now since my previous experience with the rear brakes is that they didn't seem to do much, I worried NOT about the dissimilar pads I was about to put on (PBR front, Axxis rear). After-all, I had run all manner of pads in front with the stock rears and no difference. I bled the brakes (correctly this time) and Surprise I have a firm pedal! Brakes felt strong like bull! Hooray....or so I thought.
    Fast forward 15k miles, and I have been dealing with dragging, droning rear brakes all this time. Not when you are just driving on the freeway, but when you are slowly creeping to a stop and then go to take off it sounds like Ray trying to get out of a chair. A close inspection of the rear brakes nets a pad that has worn about 70% in this time frame while the front rotors still have the hash marks visible with little noticeable pad wear. Other important details, for the last 15k miles when braking firmly but not panic stop, the rear ABS kicks on every once in a while while the front is unaffected. When performing a panic stop, the rear ABS "clamps and unclamps" harshly a few times and the car damn near stands on the nose while again the front end is unaffected. Worried, I stumbled on an interesting read on Nastysocks, regarding brake line pressure of EBD equipped cars and it got me thinking.
    So today I will be picking up new rear rotors, rear pads that match the front. I will attempt for a third time to install my stainless brake lines in the rear....I will not be beaten you ****in Subaru Monkey.
    So my conclusions are this:
    * RTFM and use the correct brake bleed procedure.
    **If your brakes feel spongy, there probably is a problem....trust your gut.
    * Replace the rear rotors and pads in kind with the fronts
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Wow you went through pads quickly...I have my stock pads still and I am at 45K.
    Jun 2006
    Nor Cal
    Many factors affect brake life.
    Driving style being a major one.
    That being said, I seem to be within the normal realm for an 06. Remember 2006-2007 wrxs came with a different braking setup than everything else. I also believe the lack of proper brake bleeding from factory on up to 80k probably accelerated brake wear. Couple that with my poor pad choice on the Axxis and this is where I'm at.
    The first 60k miles I drove very spiritedly . Then I bought a house in a different area, and the daily commute doesn't allow much spiritedness.
    Also the rear brakes lasted 80k miles.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  5. #4
    Palmyra, NJ
    On an STI?????
    Impossibru!
  6. #5
    Nov 2012
    On an STI?????
    Impossibru!
    Possibru and tru.
  7. #6
    Palmyra, NJ
    Possibru and tru.
    You must never drive over 40mph...and must use Flinstones braking methods.
  8. #7
    Nov 2012
    My perferred method of stopping is opening the passenger side window. My girlfriend is usually talking enough to cause enough resistance to stop the car.
    But seriously...I don't get it either...I have driving habits that have caused some people to say they will never drive with me again (although I consider myself a very safe driver). Maybe I take corners fast enough that the brakes don't get used that much! I never track it, so it is 90% city driving. On my 2.5I I drove it for 80K miles and never needed to change the pads either.
  9. #8
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by 06wrx4me View Post
    Do you bed the pads in after an install?
    Bed-In Theory
    2002 FORESTER S
    1998 FORESTER S
  10. #9
    Jun 2006
    Nor Cal
    Bed-In Theory
    Yes, every time.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
