Results 1 to 15 of 29
This is a discussion on Transmission and Engine Oil Change within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi all, This is my first post, so I apologize if I am being a repetitive noob! I am definitely ...
    Registered User nbrittain28's Avatar
    Jan 2013
    Maine
    Hi all,
    This is my first post, so I apologize if I am being a repetitive noob! I am definitely not a gear head (yet) and I was just looking for some opinions on the fluids I decided to use. I recently bought a 2006 WRX and I have had zero issues with the car. The dealer did not have an information on the previous maintenance, so I decided I would "baseline" the car just to be safe. After reading endless posts and threads I have decided to use Redline products. I know many people prefer Royal Purple over Redline, but my friend (mechanical engineer) told me he had great results with Redline products. So, I decided to do some maintenance and wanted to see what everyone's opinion was on my setup.
    Transmission: Redline 75w90 NS
    Rear Differential: Redlline 75w90
    Engine: Redline 5w30
    Oil Filter: Subaru OEM Oil Filter
    I live in Maine, and the temperatures during the winter can drop below -10F. The research I have done led me to believe that Redline 5w30 would be the best choice for engine oil. I chose the Redline 75w90 NS for the transmission because I heard the lack of friction modificators was better to use in the transmission than other Redline fluids (Shockproof Lightweight) and that it meets the GL-5 requirement. It also seems that most people feel that the Redline 75w90 (non-NS) is better for the rear differential because it does have friction modificators. Lastly, most people feel the Subaru OEM oil filter is the best filter to use on the car (thoughts). I have a Torx 70 bit, siphon, and anti-seize. Anything else that I am missing (besides standard tools)?
    I was hoping people could provide opinions on if my proposed plan is a good idea/bad idea. I know the opinions will range, but I am looking for solid facts as to why using all Redline would be a bad idea. So far, I haven't found anything that says it is.
    Again, thanks for the patience and understanding that I am new to the world of maintaining vehicles. Either way, is it sad that I am super excited to change my fluids...?
    Thanks in advance!
    Registered User wrx650's Avatar
    Feb 2012
    Cleveland, OH
    I made the same choice for my transmission and rear differential. I have been happy with it so far and I've had them in for about 20 000 miles. The redline oil is good stuff. The problem is that it's really expensive and you could be just as well off with something like rotella t6 from walmart (about 27 bucks for a gallon and a quart). Enjoy.
    -Noah
    2009 Spark Silver Metallic Sedan - Stage 2+
    Build Thread: http://www.clubwrx.net/forums/builds...wrx-sedan.html
    Jan 2013
    Maine
    Thanks for the info! Ya, I had heard that many people use Rotella T6, but I had also heard some people have had issues with it. Not that Redline has a perfect track record, but I have found very little negative information about it. I am not rich or anything, but an extra couple bucks buys me some piece of mind. Thanks again.
    Turtles and Penquins 11blackSTi's Avatar
    Nov 2012
    MAINEiac
    Sounds like you chose a pretty good quality product. Welcome to the forum...Where in Maine are you?
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Welcome to the forum. Check the link in my sig out. I embarked on a tranny fluid journey of discovery and landed on Subaru Extra S fluid, as many others have.
    Redline 5w30 engine oil is really unnecessary. Many of us in the community run the mobil 1 5w30 in the 5 qt jug from Walmart. Picked another one up last night for $24. Subaru OEM oil filters are the way to go IMO. My local dealer sells them for $5.50 a piece as does www.subarugenuineparts.com.
    You might need one helluva a breaker bar to put on the end of that T70. Mine was an absolute bear the first time.
    Oct 2011
    Santa Ana, CA
    Quote Originally Posted by nbrittain28 View Post
    My car would consume oil when I ran 5w30. Ever since I switched to T6 I haven't added any more oil. Being that it's a a 5w40 you should have no problem cranking at -10F.
    Plus its cheap.... er than constantly buying and adding more oil.
    Quote Originally Posted by wrx650 View Post
    You guys have the quart bottles! Lucky bastard! hahaha.
    For reference, I use the following:
    Quote Originally Posted by EJ257
    Maintenance Items:
    Engine Oil: Shell Rotella T6 5W40
    Engine Oil Filter: Purolator PureONE
    Fumoto Oil Drain Valve
    Battery: Optima Red Top (Group 35)
    Wipers: PIAA Super Sporza Silicone 22" | PIAA Super Silicone 17" | Rain-X Original Window Treatment
    Transmission Fluid: Subaru Extra-S 75w90
    Rear Differential Fluid: Subaru LSD 90LS
    Coolant: 1gal Subaru "Long Life" Coolant / 1gal Distilled Water
    Washer Fluid: Rain-X 2-in-1 Windshield Washer Fluid
    For your rear diff, I'd throw Extra-S in there instead of the Subaru LSD oil. For engine oil, it's best to try a particular oil, and get UOAs done to see how it's taking.
    Jan 2013
    Maine
    Thanks! Any experience with Redline products? I live just north of Portland, in the Brunswick area.
    -Nick
    Nov 2012
    MAINEiac
    I haven't used their products before, but I know some people who use them and have only heard good things. I use Amsoil in my car. I am from south portland, so pretty close!
    Jan 2013
    Maine
    Quote Originally Posted by 06wrx4me View Post
    Redline 5w30 engine oil is really unnecessary. Many of us in the community run the mobil 1 5w30 in the 5 qt jug from Walmart. Picked another one up last night for $24. Subaru OEM oil filters are the way to go IMO. My local dealer sells them for $5.50 a piece as does SubaruGenuineParts.com.
    Thanks for the info. Out of curiosity, why is Redline unnecessary? It is a GL-5 synthetic. I have heard many people like Mobil 1, but I have also heard just as many people who have had issues using it.
    -Nick
    Registered User PartyPizza's Avatar
    Jun 2011
    He was mistaken. Mobil 1 is the kiss of death in these cars. He probably meant Rotella T6.
    Oct 2011
    Santa Ana, CA
    Mobil 1 is the oil that my car was consuming like crazy.
    Nov 2012
    MAINEiac
    I would go with a high quality oil (like you are). Don't let someone convince you to save money by buying cheap oil. The way I figure...three/four times a year...$50-$60...I would rather pay that for good oil than put something in my car that I have to wonder about.
    Feb 2012
    Cleveland, OH
    make sure you have some sort of funnel and some plastic tubing or one of the flexible funnels. Filling the tranny can be a bit tricky without the right funnel setup.
    -Noah
    Jun 2006
    Nor Cal
    No I meant Mobil 1. Hey it's your money, if you wanna spend $50 on oil go for it.
