Results 1 to 15 of 15
This is a discussion on boost leak? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I dont know whats going on.... my car will boost to about .08mpa than creep back down till about .05mpa ...
    Jan 2013
    South Weber
    boost leak?
    I dont know whats going on.... my car will boost to about .08mpa than creep back down till about .05mpa than jump back up to .08mpa all between 5k-7krpm. I am new to the boost and not sure how to figure out how to fix or even diagnose it. Help please!
    Mt. Laurel, NJ
    Need to know what car, what year, what mods, etc. before we can help you.
    Jan 2013
    South Weber
    op... my bad, its a 2004 wrx wagon with cbe, bov (came with the car), and strut bar "front". thats about it. and its got 124k miles on her
    Texas, United States
    Aftermarket BOVs leak, more often than not.
    Jan 2013
    South Weber
    Your thinking thats my problem?
    It's a possibility.. I would perform a boost leak test for starters.
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    boost leak?
    Yep.
    Lead Wrench @ WTF Tuning, LLC
    Registered User SUBhuman's Avatar
    Feb 2013
    Montgomery, AL
    I choose to live and to
    Lie, kill and give and to
    Die, learn and love and to
    Do what it takes to step through.
    ~~Tool, "Forty-Six & 2"
    Jan 2013
    South Weber
    Thanks guys! Thats a really good vid. Ill check everything out and keep ya'll informed.
    Moderator Donkey's Avatar
    Da boonies
    boost leak?
    Most leaks don't go up and down. They just flatten out and don't produce any more boost. Sounds like you need a tune or need to slightly adjust the waste gate arm (if it is adjustable). What you are seeing is referred to as "boost oscillations"
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    Jan 2013
    South Weber
    its just the stock wastegate... idk if thats adjustable
    Quote Originally Posted by Cheets
    '04 WRX, stock turbo, the wastegate arm can be adjusted.
    Jan 2013
    South Weber
    K, sorry im such a noob. How do i go about adjusting it correctly?
    Jan 2013
    South Weber
    Should i extend the arm or shorten it? And how far, like how many turns?
    Jan 2013
    South Weber
    so i shortened the arm 1 1/2 turns and if stopped spiking so high than returning back but it seems like it is not boosting enough. It was boosting to about 13psi before and is now only boosting to about 10psi... what do you guys think?
