Results 1 to 15 of 20
This is a discussion on Looking to Mod this summer within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey Guys, I have had my 2012 wrb wrx sedan for close to a year and I love it. I'm ...
    Registered User pbart617's Avatar
    Jun 2012
    Hey Guys,
    I have had my 2012 wrb wrx sedan for close to a year and I love it. I'm going to go stage 1, using TP map. I know I want to add gauges, sway bars, short shifter, new end links and front and rear bushings. Could someone give me a list of tools that I would need to have to do these jobs, but also list other tools that I might need to just do typical maintenance on my car.
    Thanks alot
    Sent from my DROID RAZR using Tapatalk
    Mt. Laurel, NJ
    so...summer could benefit from stage 2...it needs more exhaust flow for them hot days then it will be able to have more boost on daylight hours.
    Dec 2011
    Pottstown PA
    look up install threads for these parts and that will give you some tools needed for these part installs. seems like your on a nice build plan so hope everything goes well. but jack, jackstands, ramps, all size sockets, 3/8", 1/4", 1/2", also i love ratchet wrenches, multimeter, crimps, test light, wire crimper, screw drivers-phillips/flat, vice grips, mallets, beer, torches-propane ones are alright and can sometimes do the trick, pb blaster, bearing grease- i tend to use the red sticky kind, breaker bar, tq wrenches for lugs and other things, i always torque down my lugs now. theres a few things but theres always a tool ya seem to be missing when ya need it lol.
    Mt. Laurel, NJ
    box wrenches and a good socket set both in metric sizes.
    Tactrix Cable and a laptop running ECU Flash and Rom Raider for the Stage 1 flash.
    You can take apart a whole Subaru with 8mm, 10mm, 11mm, 12mm, 14mm, 17mm and 19mm sockets.
    Jun 2012
    Re: Looking to Mod this summer
    Perfect, beer sounds like the most important. I do want to go stage 2, but am weary about my warranty although I know all I need is the tune and down pipe. I'm still not even sure if I'm going to do stage 1. But I know I want to do suspension and cosmetic mods.
    Turtles and Penquins 11blackSTi's Avatar
    Nov 2012
    MAINEiac
    To be honest you run just as much risk on warranty by doing suspension mods. Anything you do actually. Obviously screwing with the engine is the most likely thing to cause any issues, but I could easily see warranty denials due to suspension upgrades. It is a risk we all take!
    Jun 2012
    You know the more I think about it, the more I think I'm just going to do it regardless of the warranty. Stage 1 sounds perfect although I know stage 2 will come, people say the mod bug will hit. Even though I believe it did as soon as I signed up for these forums, when I bought my car
    Nov 2012
    MAINEiac
    Quote Originally Posted by pbart617 View Post
    I think that is the choice *most people on here ultimately come to as well
    Jun 2012
    Thats what i have come to realize. The more i think about it too, everything can be fixed, so we'll see how it goes.
    Jun 2012
    Quote Originally Posted by Ruh Roh View Post
    3 ton, jackstand seem to be the most popular ones to use around here. any other suggestions?
    Mt. Laurel, NJ
    3 ton Jackstands?
    Jun 2012
    3 ton Jackstands?
    Yes, sorry having a hard time typing today. That is a bad thing when you work in IT for a living.
    Mt. Laurel, NJ
    I know the feeling all too well. A solid set of jackstands is key. A set of ramps isn't a bad idea either, especially for simple oil changes and especially if you plan on doing Swaybars, which need to be installed under load. A good floor jack makes life easier as well. I got a low-profile floorjack from Harbor Freight, and I love it!
    Jun 2012
    Any ideas for a good set of jack stands, ramps, and lp floorjack? I have been looking but not sure if they are any good or not.
    Dec 2011
    Pottstown PA
    jackstands? ya mean woodblocks? much cheaper. jk. ive upgraded to them lol.
