First off, what troubles have you been having?
Yes that is the OE clutch kit that will include everything you need, except the flywheel. Which should be replaced(duelmass). But some can get away with a resurface. Not a bad price if it does include a flywheel, if not still not a BAD BAD price for an "8 hour" job.
Costa Mesa plates.... check out Project Import down in Anahiem, they have a sweet flat rate deal on clutch installs(according to their site). Shouldn't be too much more to replace the rear seal once the clutch is out. But first answer my first question.
LinkBack URL
About LinkBacks
