Hmm...I once had the dealership spill oil on my engine when they did an oil change (in my old blazer) and I had a similar experience that you are describing. Had kind of more of a burning plastic smell though.
This is a discussion on Heat smells like gas within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I picked up my car today from the dealership. They did an oil change and tire rotation. I noticed later ...
I picked up my car today from the dealership. They did an oil change and tire rotation. I noticed later that day that while driving home in the snow, the heat coming out of the vents had a raw gas smell to it. It was set on a low setting around 78. I cut the heat and the smell seemed to vanish. Turned it back on, and the smell returned. Any ideas anyone???
- 2011 WRB STI
Cobb stage 2 tune ~ Invidia turbo back exhaust
So I checked under my hood this morning and it turns out the tard that did my oil change forgot to put the cap back on. Found it sitting on top of that plastic bay protector. Luckily I could squeeze my arm down and reach it. I would expect this type of work at jiffy lube but not a Subaru dealership. What a joke.
- 2011 WRB STI
If oil sprayed all over the engine bay, you should take the car back & have them clean it up.
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
The Big 2011/2012 Mod Thread
"Just Leave me alone. I know what I'm doing"- Kimi Räikkönen
^ And find out who did the work. Accountability!
Rod
2012 DMG WRX base Sedan Cobb S1 93 Octane
Older than dirt Mob#1
"Just remember, with great power comes great responsibility" - rarrior
Yeah I'm definitely going to contact the dealership.
Also now I'm feeling a bump, bump, bump in the right tire it seems. Almost like when a large rock is stuck in your tire. Could this be from the tire rotation they also did and the tire needs to smooth out its treads or is this a ridiculous assumption and they f'd this up too?
- 2011 WRB STI
Check your tire pressures as well. May not hurt to take the wheels off and re torque them by hand though.
If any oil spilled in the bay.. I'd follow Sasquatchs engine bay cleaning instructions.
2011 STi Build LogOriginally Posted by Trainrex
Isaac -- 2003 WRX sedan Stg II
He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
You mentioned that it snowed. The vibration in the tires could also be from snow in the wheel well.
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
Thanks for all the feedback guys. I'll see whats up tomorrow.
- 2011 WRB STI
