Results 1 to 8 of 8
This is a discussion on Kartboy Rear Shifter Bushing within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just installed a Kartboy short throw shifter and the front bushing. The rear bushing i had a problem with ...
    Nov 2012
    Brooklyn, NY
    I just installed a Kartboy short throw shifter and the front bushing. The rear bushing i had a problem with and i managed to mess up the bolt on the driver side of the rear bushing. I ended up putting the oem one back on with the stripped bolt on there . The other bolt is fine but that stripped bolt is at an angle. It is secure so i'm not worried about it falling out.
    can you guys give me some ideas of how to fix this? or am i sol
    this is for a 2013 wrx
    Aug 2012
    Bristol, CT
    is just the bolt stripped out? cut it out and throw a new one in. or you might need to retap it
    Nov 2012
    Brooklyn, NY
    i dont think the bolt is stripped i think i may have carve new grooves in the hole
    i wont be able to retap the hole cuz of the location?
    Aug 2012
    Bristol, CT
    you might be able to retap the hole
    i retaped rear slide pins at work the other day. you have to do the hole and bolt though
    Nov 2012
    Brooklyn, NY
    do you think it'll be a problem if i jsut leave the oem one on there?
    Aug 2012
    Bristol, CT
    hnestly, as long as it isnt making any noise, and the bushing is working as it should...i would leave it there too. but if you ever needed to replace the bushing that's all you're going to have to do. you'll still be able to get the bolt out, maybe still get it in again but if you can't thenyou'll have to tap it...but that's only if you need to replace the bushing again. you should be alright
    Nov 2012
    Brooklyn, NY
    aite thanks for all the help man
    Nov 2012
    Brooklyn, NY
    what noise should i be looking for?
