Yup, I use rotella T6 and Prova filters.
This is a discussion on What kind of oil does subie dealer use? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Zman13 I know the manual states change the oil every 7.5k buy I live in the mountains ...
2011 Subaru WRX Premium
1988 Ford Mustang GT
2000 Jeep Wrangler TJ
Opinions in oil threads are meaningless. Only two things matter:
1. Manufacturer specs while the car is under warranty.
2. Actual data.
Get actual data and find out. Pull a sample and spring for at least one used oil analysis.
Although yes, I would think you are OK and I would in fact go longer in my own car, my opinion is meaningless. Data do matter; go after them instead.
Thanks MainFrame, great site.
Again, a caution, no matter how good the data do not stray from SOA's specs while under warranty and keep all dated receipts, for warranty claim purposes.
most dealerships use the cheapest option at the time. We normally have castrol in our bulk, but you can request any oil you want, just make sure to be aware the price is different.
Lead Wrench @ WTF Tuning, LLC
One thing to keep in mind when looking at UOAs is that many major brands of oil have been reformulated in recent years to be more friendly on the emissions control systems. What this usually means is much lower zinc content along with other things, and in turn worse performance. If you look at UOAs of Rotella T6 for example.. T6 used to have great results, but then just a year or two ago they removed the majority of the zinc from the formula. The high zinc content of T6 was on of the main reasons it performed so well in the past. You can sitll get high zinc content oils from companies like Amsoil, but you're going to pay a premium for that.
If oil performance is a high prioirty, then I would consider using a zinc addative along with your choice of synthetic oil.
If you are under warranty though the high Zn formulations may not -- in fact if it were up to me they would not -- meet the correct specification. Just a caution for the new car guys. Follow the SOA spec.
Do you own a subaru?? Yea.. you dont have a warranty..
I like warranties.
In any case your motor is producing higher output than any of the stock motors available I think, and your requirements may be different as a result, depending on your use.
im going to use the manufacturer specs oil while the car is under warranty for sure as far as the weight of the oil to use. I think they recommend 5-w30 ill have to get the book back out and check! But as far as brand when im ready to change my oil around 4k im going to do a ton of research. Id like to use an oil with a good reputation and that has additives it it like Amsoil or Redline maybe. As far as the guys using rotella T6 ive never even heard of it..LOL but i will look into it!
Specs limit API grade, not just viscosity, so get the right API grade also. I don't think either of those firms, neither which I'd buy, have a Group IV+ synth of the correct API grade (don't you require SM or SN?) though I may be wrong.
Check the SOA requirement for API grade, viscosity, and change interval and keep dated receipts.
