Results 1 to 8 of 8
This is a discussion on Boost creep! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So, I'm on the stage 2 COBB OTS mapp with an invidia high-slow catted DP. I've recently been realizing im ...
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    Boost creep!
    So, I'm on the stage 2 COBB OTS mapp with an invidia high-slow catted DP. I've recently been realizing im boosting 20PSI at some points. Should I run the Low WasteGate map, and will this solve my problem??
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    Boost creep!
    Did you pull logs to see this, or look at your boost gauge? Is your downpipe catless?
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    Lando Calrissian DemonWRX's Avatar
    Jul 2011
    Cloud City, Bespin
    When you hit 20psi, what do oyur AFRs look like?
    Just because you are hitting 20 does not mean you actually have a 'problem' exactly. If your ECU is compensating with added fuel, you are fine. If you are running lean, or gettign knock, you have issues.
    Stink-Eye Mob #39
    N.E.R.D. Operative #8
    Dec 2011
    Pottstown PA
    Quote Originally Posted by Rambo View Post
    its catted
    May 2010
    Pittsburgh, PA
    It's probably not boost creep. To test for boost creep, you would have to force your wgdc to zero (mechanically or in the ECU). For now, try the lower wastegate map. It should help.
    Otherwise, contact Cobb.
    2011 STi Build Log
    Nov 2011
    North Jersey
    So to further inform you guys, I'm using the cobb AP on the boost gauge to see what boost im hitting. And also, I do not pay attention to AFR, because quite honestly i have NO idea what numbers to be looking for (putting flame suit on)
    This isn't directed just at you, Mike, just in general, but I don't understand why anyone would bring up an issue with tuning without supplying a datalog. That said...
    Quote Originally Posted by Heide264
    Try the LWG map from Cobb. If you're still overshooting, try the SLWG map.
    Registered User jsBLwrx's Avatar
    Oct 2012
    MD
    Re: Boost creep!
    ^^^ +1.... Initial stage 2 OTS map was ..... speechless. The boost spike was beyond the boost gauge and settled near 20psi...
    The stage2 lwg map spiked to 20psi and settled back down immediately to 18psi which is fairly close to the target boost of 18.5psi for 2013 wrx...
    So. Do try the lwg map
