Why? i don't even use a funnel, its pretty hard to miss our oil fill pipe. If you need one just get a normal one from autozone or someplace.
This is a discussion on Threaded oil fill funnel? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Has anyone found a cheap threaded funnel? I've seen some for -ish shipped, but that's too much....
Has anyone found a cheap threaded funnel? I've seen some for $30-ish shipped, but that's too much.
'02 WRX Wagon
RCE wagon springs
Koni inserts
Com-C Top Mounts
Kartboy Endlinks
Sedan rear swaybar
Others little stuff
2005 WRX (Silver) SoCal Subie
Blobeye Syndicate #1093
http://www.clubwrx.net/forums/builds...al-05-wrx.html - Build Thread
http://www.flickr.com/photos/34009765@N06/ - For whatever pics i take.
Mikie13-Spend money on hookers and blow. That's a better intake.
-Noah
2009 Spark Silver Metallic Sedan - Stage 2+
Build Thread: http://www.clubwrx.net/forums/builds...wrx-sedan.html
^^(both y'all)too rich for my blood. Cut up quart bottle is enough for me =D
Posted from a fone.
-Noah
Isaac -- 2003 WRX sedan Stg II
He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
Go to a Chevron fuel station, the funnels are paper so single-use but free, and the Van Houte coffee is very good when ground on the spot using their grind/brew combo machines.
I cut the upper part of the windshield washer fluid bottle... And even have a cap to close it...
-Noah
