Is the car completely stock, or is it modded? If modded, what exactly has been done to it?
This is a discussion on Engine cuting out when coming to a stop. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi All I have just purchased 2005 WRX and just this morning i was driving home coming up to a ...
Hi All
I have just purchased 2005 WRX and just this morning i was driving home coming up to a set of lights with my foot on the brake and changed into neutral and then the car's idle went to zero and the engine cut outjust like that!!.
And then it has done it 4 times today completely out of the blue with noooo engine lights etc etc.
PLEASE IF ANY ONE CAN HELP ME OUT WITH SOME SORT OF SOLUTION THIS WOULD BE GREAT THANKS.![]()
Thanks for the reply.
The car is completely stock with no mods.
Ok thanks I will try that first then let you know the out come.
Also make sure battery connections are secure, as well as grounding points.
Ok ill check that to thanks![]()
Try spark plugs
iacv is a common perp for this problem
The engine needs more sand... J/k you might want to clean the mass airflow sensor too...
Hawk-Eye Alliance #801
Yes... you need engine management for engine modifications
http://www.clubwrx.net/forums/tuning...ne-mods-6.html
