from what I've read in other threads, you are supposed to change the crush washer on the plug with each oil change. Alternately, you could get a valve that lets you change the oil easily without tools.
This is a discussion on Small oil leak (With pictures) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was changing my oil today and noticed oil on my oil pan. I have never seen any oil on ...
I was changing my oil today and noticed oil on my oil pan. I have never seen any oil on the ground where I park so it must be a slow leak. I looked all around and could not find a source. The only thing that comes to mind is that the oil plug was leaking and that the air from the moving car was blowing it along the oil pan? Are you suppose to change the washers on these plugs? Thanks.
David - '05 WRX, stock except uppipe and rear swaybar
Thanks.
Do you do your oil changes yourself? If you do, then yes, every oil change needs a new washer. When I buy my filters I get the washers with them.
Yes, you can use a Fumoto quick drain valve. Haven't used it myself, but I hear that it is painstakingly slow.
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
The Big 2011/2012 Mod Thread
"Just Leave me alone. I know what I'm doing"- Kimi Räikkönen
2005 WRX (Silver) SoCal Subie
Blobeye Syndicate #1093
http://www.clubwrx.net/forums/builds...al-05-wrx.html - Build Thread
http://www.flickr.com/photos/34009765@N06/ - For whatever pics i take.
Mikie13-Spend money on hookers and blow. That's a better intake.
Facebook me here
Originally Posted by Mikie13
change your drain plug washer
Lead Wrench @ WTF Tuning, LLC
Yes you need to replace it everytime you remove the drainplug... A crushwasher creates a seal everytime it is decompressed from tightening the drainplug...
Hawk-Eye Alliance #801
Yes... you need engine management for engine modifications
http://www.clubwrx.net/forums/tuning...ne-mods-6.html
A truck sump can exceed 50l whereas a car sump is typically 5l. I use a Fumoto valve in two different cars, love it.
Anyway, you can change the crush washer without a full oil change. Use your thumb and work fast. Make sure the new washer goes on the right way though and have top up oil handy since inevitably you'll lose some.
I think I'm having the same problem. I changed my oil but forgot to do the washer, and not I think it's leaking slightly. That, or I need to replace the entire pan. Sucks because now I'll need to change the oil AGAIN, right?
To the face!
04' Stage 2 WRX | Premium Silver. Premium Sex.
youll need to replace your oil pan if you strip the drain hole out and tightening the drain plug doesnt wrk. or you can get an oversized drain bolt
I'm just going to wait until I change the oil next to change the washer. It's such a small leak.
Should I use a metal washer or rubber gasket? I see both kinds for the WRX.
You can get a box of 20 metal crush washers RockAuto.com for like $2. No more leaks
