Page 4 of 4 FirstFirst 1234
Results 46 to 50 of 50
This is a discussion on Catalytic converter overheating? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Read somewhere (can't remember if it was here or another forum) that said a high (but not high enough to ...
  1. #46
    Jan 2010
    Loganville, GA
    Read somewhere (can't remember if it was here or another forum) that said a high (but not high enough to send a CEL code) ETG reading can also sometime trip a P0420 code. Anyone else run across that?
  2. #47
    Oct 2011
    Santa Ana, CA
    I thought the Vagcom didn't work for flashing?
    Only works on 2004 and 2005. Needs a jump to get the 12v to flash though:
    http://i2.photobucket.com/albums/y18...n/IMAG0117.jpg
    But its unregulated so its a little high... so I just turn on my headlights.
  3. #48
    Jan 2010
    Loganville, GA
    You guys have pretty good luck w/used components such as cats, etc.? Don't really want to try modding it right now, at least not until we figure out what exactly is going on and see if there's more underlying problems. I have some leads on some fairly low mileage (30-40K) up pipes and down pipes. Of course my mechanic would advise against it, but stock parts are so expensive, especially the down pipe cat.
  4. #49
    Oct 2011
    Santa Ana, CA
    I don't think anyone here with the exception of SD_GR would advise getting a OE uppipe. You don't even HAVE to take out the EGT sensor in the up. But it's recommended. Thats what my dealer did.
    As for your failing cats. What my dealer did to diagnose my clogged UP cat was take a infrared heat gun to it. The clogged cat was extremely hot. But the remainder of the exhaust was much cooler vs the UP. You can try that.
    Used cats... no experience
  5. #50
    Quote Originally Posted by UEDan View Post
    I'd not replace a catted up pipe with a catted up pipe. However a dealer that wouldn't is violating federal and CA law.
