Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 50
This is a discussion on Catalytic converter overheating? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by dttruax Question: would this code mean that the pre-cat is going bad, or just the mid-cat? Either, ...
  1. #31
    Texas, United States
    Quote Originally Posted by dttruax View Post
    Either, both, neither.. there are a lot of things that could cause that reading. Failed sensor, exhaust leak, rich or lean condition, or a problem with one of the three catalytic converters. I would not suspect that code to be thrown by a failing uppipe cat though, since you can run catless uppipe without having to worry about throwing that code.
  2. #32
    Jan 2010
    Loganville, GA
    The other symptoms (like the hot almost burning smell coming from under car/engine bay makes me believe the cat was overheating, etc.
    Now, there's no cat in the downpipe, correct (item "M" on the schematic on the previous page)?
  3. #33
    The stock downpipe should have a catalytic converter in it..
    A lean condition can cause excessive heat. But if the car is stock I wouldn't expect it to run lean unless there's a mechanical problem somewhere.
  4. #34
    Mt. Laurel, NJ
    Stock downpipes have 2 in them.
  5. #35
    Jan 2010
    Loganville, GA
    So...... there's actually 4 converters on a 2004 WRX?
  6. #36
    Three
  7. #37
    Jan 2010
    Loganville, GA
    I only ask because my mechanic is having a heck of a time w/the local Subaru dealer and getting the correct part. My mechanic basically thinks the converter in the downpipe (item "M" on the subarupartsforyou schematic.... which I can't find anywhere) is bad and needs to be replaced, but Subaru sent him the mid-cat assembly (item "P").... and I think the dealer wanted over $800 for the downpipe assembly.
  8. #38
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    Buy used off someone who went stage 2. You can probably get the whole stock exhaust for $1-200.
    Also check the wires from the rear O2 sensor. Mine rubbed on the drive shaft and it has worn away the housing shorting the sensor on the drive shaft. I had a P0420 code and no CEL. Just passed Colorado Emissions with it that way as well.
  9. #39
    Quote Originally Posted by SKI.WRX View Post
    ^this
  10. #40
    Jan 2010
    Loganville, GA
    Know anyone???
  11. #41
    Jan 2010
    Loganville, GA
    anyone know the part # for the downpipe assembly w/converter for a 2004 WRX?
  12. #42
    Know anyone???
    FS: (For Sale) 2005 WRX Stock Downpipe and Up pipe - NASIOC
    there are several others listed too..
  13. #43
    Jan 2010
    Loganville, GA
    Three
    So since there's 2 converters between the 2 oxygen sensors, it could possibly be one, either, or both that might be bad. Oh goody.
  14. #44
    Oct 2011
    Santa Ana, CA
    Since we already suggest you replace the stock up with a catless unit....
    GET A (used) CATLESS DOWNPIPE!
    Your car is a 2004. $10 Vagcom cable + $50 XPT tune. More power, better fuel economy and no more friggen cats!
  15. #45
    Quote Originally Posted by UEDan View Post
    I thought the Vagcom didn't work for flashing?
