Also I have been testing all of this with the clutch switch jumped to ground full time to speed up the process and prevent me from having to push that thing in all the time. And when I tested the main relay to make it pop it did pop and it did transfer voltage however it only popped once. I was under the assumption it should pop 3 times.
LinkBack URL
About LinkBacks
