Results 1 to 15 of 18
This is a discussion on Brake Fluid within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey all - just curious what people are using for brake fluid. I am getting mine changed soon and I ...
    Turtles and Penquins 11blackSTi's Avatar
    Nov 2012
    MAINEiac
    Brake Fluid
    Hey all - just curious what people are using for brake fluid. I am getting mine changed soon and I figured I might spend a few bucks and bring my own in rather than have them put in whatever they use at the dealership.
    Thanks!
    zax
    zax is offline
    Moderating the World! zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Motul RBF600
    Facebook me here
    Moderator Donkey's Avatar
    Da boonies
    Any DOT 3/4 synthetic is fine.
    2002 FORESTER S
    1998 FORESTER S
    Apr 2007
    8000' up in Colorado
    ^^^ What he said.
    Motul, ATE Superblue, and Castrol are the three most used ones, mostly because they're the easiest to get, but any DOT4 fluid will more than do the job unless you have a dedicated track car that will run extended times on the track. I've used both of the first two pretty extensively on the track in a couple of different cars (Subaru and Porsche) and they've both worked perfectly.
    Make sure when you replace the fluid that it's a full flush and replace and not just a replace (which will leave some of your old fluid in the system). I'd also suggest you add stainless steel lines at the same time since those require replacing the brake fluid too. They'll significantly improve your pedal feel.
    Scott
    Is the car strictly DD duty? Auto-X? HPDEs?
    Quote Originally Posted by Donkey
    As a general rule, yes. I use ATE SuperBlue, personally.
    Brake Fluid
    Alternating colours makes it easy to know when fresh fluid reached a caliper dso there's that advantage. For my cars I just buy Castrol locally though. YMMV.
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    Same. Never had an issue with it, and it comes in two colors, for flushing purposes.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    Apr 2007
    One other thing to be aware of with respect to DOT4 fluids is they must be changed yearly. They have a shorter service life due to their properties than their less effective counterparts, which can be left for several years in a car between replacement.
    Scott
    Brake Fluid
    I have read the ATE DOT4 change interval is up to 3 years; this is comparable to DOT3.
    Nov 2012
    MAINEiac
    Great thanks for the input everyone.
    My car is a daily driver. I don't track it. But any chance I get to put something better in I always do. For example, I know I don't need to run good oil in the engine, but I always use AMSOIL signature series and Oil filter just because. Who knows what the dealership uses.
    Anyway, I will research some of the suggestions.
    Thanks again!
    Dec 2011
    Pottstown PA
    Wearever Dot 3 from local auto parts store. it does the job.
    Nov 2012
    MAINEiac
    Probably a dumb question, but how much fluid do you need for each time you change it?
    May 2010
    Pittsburgh, PA
    This.
    Different color brake fluid makes life easy. I put in Motul last time. Will use ATE SuperBlue next year. Super Blue is cheaper for what its worth.
    I have also heard that DOT4 fluid requires changing more frequently. It is supposedly more hydroscopic than DOT3. I believe a couple books I read pointed that out. Either way, if you aren't tracking your car, you should be fine with every other (or every 3) years as a maintenance interval. I'd suggest flushing them before every few track events otherwise.
    2011 STi Build Log
    May 2010
    Pittsburgh, PA
    I believe it is .7 of a quart. I would buy two to be save. You can always leave unopened brake fluid sit on the shelf for next time. It's frustrating to run out. Especially if you are throwing on stainless lines, plan in case you find a leak. The DOT 4 fluids (for me) are near impossible find locally.
    2011 STi Build Log
    Nov 2012
    MAINEiac
    Awesome...Thanks!
