Really? This is a serious question? You just tossed on an up pipe and down pipe and expected your ECU to just adjust for corrections? Maybe you shoulda done some research huh? Get a tune. That will fix it.
This is a discussion on bank one sensor check engine light, plz help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi, guys! after i upgraded my stock down and up pipe to catless up and down pipe, my engine light ...
hi, guys! after i upgraded my stock down and up pipe to catless up and down pipe, my engine light pops all the time, bank one sensor message, any trick that i can do to make it go away? or i guess i have to just get used to it, thanx.
Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
Your description of the CEL is not clear. The work done will generate two CELs usually. Both can be addressed mechanically or electronically. Search "CEL fix" for both up pipe and down pipe.
You could always put catted up and do instead so your o2 won't bug out
thanx guys, thats my first turbo car. im just new to wrx. thax
DO NOT use a Cat in the up pipe. simple and cheap resistor mod will take care of the up pipe CEL.
2.2K Ohm Resistor Mod
