Results 1 to 2 of 2
This is a discussion on turbo water drip on startup within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Is there a exhaust condensation weep hole under the downpipe to turbo seal erea? I've been checking for a phantom ...
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    Is there a exhaust condensation weep hole under the downpipe to turbo seal erea? I've been checking for a phantom coolant leak but this was definitely water. Slooooly dripping onto the frame from under the turbo. Definitely water. Weird. Ideas?
    The A/C exit line is on the firewall and exits below the turbo area also. If you are using the defroster on the windscreen, the A/C will be on constitutively.
