Results 1 to 5 of 5
This is a discussion on 06 WRX low beams/DRLs out within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2006 WRX with stock headlight assembly, I was driving and my BOTH of my DRLs and low ...
    Registered User Dirty Bucket's Avatar
    Nov 2011
    Augusta, Maine
    I have a 2006 WRX with stock headlight assembly, I was driving and my BOTH of my DRLs and low beams went out. High beams and parking lights work fine. I quickly checked the fuses and found nothing blown. I didn't get a chance to check the bulbs, I just found it odd that Both of the left and right lights went out at the same time. anyone have any ideas what the problem might be?
    Moderator Donkey's Avatar
    Da boonies
    Check the fuse and the lowbeam relay.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2011
    Augusta, Maine
    This morning when I started my car, both my DRLs and my low beams worked. This happened once before just for not as long. Any ideas?
    Registered User v6mx6ls36's Avatar
    Jan 2009
    El Paso Texas
    Check the relays , mine did something similar with the high beams , come to find out the relays just worked themselves loose , the DRL , high and low beam relays are all in the same spot next to each other above the glove box , there clearly marked.
    Nov 2011
    Augusta, Maine
    Awesome, I'll check them when I get a chance. Thanks.
