What do you mean "even when it's idling"? The turbo cannot spool without the engine being under load. Also, your car shouldn't have a blow off valve, unless someone changed out the stock bypass valve. What has been done to the car? When did this problem start? Also, what boost pressure does it achieve when it seems to be working?
LinkBack URL
About LinkBacks
