Results 1 to 7 of 7
This is a discussion on Power steering screech within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey everyone. I own an 08 STI and have about 77,000 miles on it. Getting a screech from the power ...
    Registered User Yamahar6311's Avatar
    Aug 2012
    Los Angeles
    Hey everyone. I own an 08 STI and have about 77,000 miles on it. Getting a screech from the power steering when cold all of a sudden(only when wheel is turned), when it warms up its good. Is this an issue?
    Registered User jgardiner's Avatar
    Oct 2010
    Calgary, Canada
    It sounds like you just need to tighten the drive belt.
    Aug 2012
    Los Angeles
    Thanks
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    Quote Originally Posted by Yamahar6311 View Post
    Yes this is an issue. Your belt is slipping. I'm not sure if you can tighten the belt or need replace it. From what I know these cars use a stretch belt with no way to tighten. Someone needs else needs to verify if its possible to tighten the power steering, and alternator belt.
    2011 WRX Limited Spark Silver (5 Door)
    KHP
    KHP is offline
    Oct 2010
    Reno, NV
    ok did a little bit of research. The Power Steering and alternator belt can be tightened. AC belt is a stretch fit that cannot be tightened.
    Apr 2007
    8000' up in Colorado
    If the belt was the issue, you'd most likely be having issues with your alternator too. But it's always worth a shot to try and tighten it since that's free.
    Scott
    Aug 2012
    Los Angeles
    It probably is the belt. I just changed it a few days ago. Didn't put 2 and 2 together. Just didn't tighten it enough. Thanks everyone
