Sounds entirely possible the ignition is bad. This was a frequent problem on earlier Subies.
This is a discussion on What could cause loss of power to radio, heater controls, and dash display ? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok, I was heading home from work a few days ago and noticed that the dash display in my '09 ...
Ok, I was heading home from work a few days ago and noticed that the dash display in my '09 REX (that shows temp/mileage/time) was out. In further checking, I discovered the radio and heater/ventilation controls were out as well. wtf. The car seemed to drive ok, so I proceeded across town.
I then pulled every fuse out of the fuse box, and inspected it for being blown and re-seated. None were blown. Tried to start the car, and after about 5 seconds of cranking, it finally started. I soon noticed that it was not boosting, and seemed to be in a limp-home mode. I reset the ECU and then reflashed. Everything is now working ok for the last few days.
My concern is that if it had been real cold or dark that day, that I would not have had defrost or lights, and would have been totally screwed.
Any idea what may have caused this issue? Some other people have suggested a bad ignition switch. The only clue I have to relate to that is when I was going to reflash with my AP, it asked several times to "TURN IGNITION KEY OFF AND THEN BACK ON" before it would allow me to proceed to do the reflash.
Scott
