Does it crank? How old is the battery?
This is a discussion on 02 wrx won't start within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 02 wrx that won't start, i changed the fuel pump and it ran great for 2 days, ...
I have a 02 wrx that won't start, i changed the fuel pump and it ran great for 2 days, now it won't start again, i can hear the fuelpump whir when i attempt start up so its getting power, any suggestions?
It cranks the battery is about 3 years old, i sprayed some throttle body cleaner into the air intake and the engine ran for a few seconds
Either you're not getting spark or you're not getting fuel. Given your statement above, I'd suspect fueling. Even so, spark is easy to check. When was the last time the spark plugs were replaced? What's the gap? If you replaced the fuel pump and it worked, there's likely something causing the fuel pump to burn. Did you replace the fuel pre-filter when replacing the fuel pump?
Facebook me here
Originally Posted by Mikie13
