Results 1 to 5 of 5
This is a discussion on Turbo sounds very loud when I step on the gas within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys I have a 012 wrx with approx 5200 miles on it and recently im starting to hear the ...
    Jul 2012
    Hey guys I have a 012 wrx with approx 5200 miles on it and recently im starting to hear the turbo like really loud. Is not leaking or anything it just sounds like if it would have an aftermarket intake but it does not have one
    Suspect leak, take it in to dealer, expect no action taken.
    Registered User naked_dave1's Avatar
    Nov 2011
    Appleton WI
    My '12 had the inter-cooler boot come loose.
    Check out this thread to see if it could be your issue.
    Boost Leak? 2012 WRX
    Apr 2007
    8000' up in Colorado
    I'd also suspect a leak. There's a reason it sounds louder, and that's really the only possible cause. Good thing you have a warranty so it won't cost you anything to get it fixed!
    Scott
    Jul 2012
    Thank you for ur answers i took it in and it was the boot like one of you said. Now everything is runnin perfect. Thanks again
