Results 1 to 8 of 8
This is a discussion on Headlights not horizontally adjustable? (2013) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I just called my service advisor because the other night when it was foggy, I noticed my headlights seemed ...
    Registered User crash55's Avatar
    Nov 2012
    Maryland
    So I just called my service advisor because the other night when it was foggy, I noticed my headlights seemed off a bit. The left light is either too far to the center of the car, or the right light is too far right. It looked to be low beams, not fogs. The service advisor said this is not adjustable left to right, only up and down. Is that true?
    2013 DGM Hatch WRX - STI STS currently only mod
    Nov 2012
    Maryland
    Bump. Hoping for some insight before I go in for service on Tuesday. Thanks all!
    Registered User chutoyy's Avatar
    Sep 2012
    Sacramento/Orange County
    It's not true. There are two adjustments... left/right and up/down. The easily accessible one is the up/down.
    left/right adjustment screw is covered by a plastic block-off that you need to pop off the back of the headlight.
    On the black housing... you can see the screw in the top corner of the headlight... that's left/right. Sorry... this was the only pic I had on hand.
    2013 WRX Plasma Blue Pearl
    Nov 2012
    Maryland
    That's perfect. Thanks for the info. I'll press the issue with them on Tuesday.
    Nov 2012
    Maryland
    Does anyone have more detailed info on this? I'm at my second dealership now saying that it's NOT adjustable. However atleast this dealership offered to test it and will replace the light if it's actually off. We'll see on the 22nd when I get in. However if you have a tech document or something proving it's adjustable, I could show them that. Thanks in advance.
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Just replied to your alignment thread. Your dealer seems unwilling to help with much.
    There has to be some adjustment. Look for the screws / bolts yourself.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Sep 2012
    Here's the adjustment screw... I believe this was the driver's side lamp... You need to pop off the protective plastic cover to access the screw underneath.
    Apr 2007
    South FL
    ^^^bump to help others
    it's the black cap under the letters "SAE" in the above pic. Once cap is off, it's the same 8mm bolt to turn as the up and down leveling. It's hard to access and get that cap off. flathead screwdriver pushed into the 3 horizontal slots worked, but it took some time to wiggle it off.
    turn bolt clockwise to turn the driver's side light to the left and vice versa
