Same here, I have a 13 with 600 miles on it and I noticed the coolant is at the VERY minimum level. One ounce less and it will be low, guessing it just was filled up that way though.
This is a discussion on Coolant Problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2012 wrx, and the other day I decided to pop the hood to check on everything and ...
I have a 2012 wrx, and the other day I decided to pop the hood to check on everything and I noticed my coolant is below the low marker in the tank. Mind you my car only has 3,800 miles on it. Its weird that the coolant is almost gone. The only mods I have done is a nameless axle back muffler delete. Any ideas of what could be causing this? The car hasn't over heated yet or anything.
Is this with a cold engine? What does the level look like after the car has run a bit.
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
The Big 2011/2012 Mod Thread
"Just Leave me alone. I know what I'm doing"- Kimi Räikkönen
For me, it is with a cold engine. But the coolant resovoir only had something like "full" and "low" marked on it, rather than "full when hot" or "full when cold" like other cars I've owned.
I'll check it tomorrow with a warm engine and see what it looks like.
When I looked at it this morning it was cold and off and the it was below the low level, the other day when it was running it was about 2 inches above the low level
I had the same issue with my '12 with about 5,000 miles. Noticed it was low and filled it up. It's been full for the past 4 months. I heard that not all the air gets out when they put the coolant in at the factory?
Hmm, I hope thats the case, im bringing the car in for service this saturday so ill see what they say.
It is not an issue. If the coolant is low & the car is within warranty, they'll just top it off.
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
If there are no leaks and the car isn't overheating, I'd just top it off. Keep an eye on it for good measure.
Alright thanks guys
