Boost Leak? 2012 WRX - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
This is a discussion on Boost Leak? 2012 WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by naked_dave1 I didn't do data log (would have liked to but didn't have time) They knew the ...
  1. #31
    Apr 2012
    NW Suburbs, Chicago
    Quote Originally Posted by naked_dave1 View Post
    They knew the problems because there was a bulletin posted by Subaru about that exact issue, so my guess is they didn't do a boost leak test.
    Did you ever check to see if you were hitting 16.5 psi before you got this fixed? Also, can you please point me to where you saw the bulletin posted by Subaru about this?
  3. #32
    Apr 2012
    NW Suburbs, Chicago
    Just got an idea, naked_dave1. Since my concern is that I have a boost leak based on my data log and we are running the same maps on both our cars, would you mind data logging a pull on your car and posting the results here? I just want to see if you get that same dip and regrowth of boost after spiking at 16.3 psi that I am seeing on my car.
    The parameters of my data log were 4th gear, WOT from ~3000-5000 RPM. I was only logging 15 metrics including Throttle Position, RPM, Wastegate Duty and Boost so that I got good resolution.
    I'd appreciate it if you could grab a pull in 4th gear and one in 3rd gear. If it's easier for you to email me the data logs to me that's be great too. Then I could compare them to mine to see if my car does in fact have the same type of leak that yours did.
    Thanks.
  4. #33
    Registered User naked_dave1's Avatar
    Nov 2011
    Pewaukee WI
    Quote Originally Posted by hindude View Post
    I do remembering checking that, and I wasn't hitting full boost. I think I was hitting 13psi. The dealer is the one that saw the bulletin, no sure where non-dealers can check. And I can try a data log, but might be a bit as I'm traveling.
  6. #34
    Jun 2012
    NJ
    Its the tb hose...
  7. #35
    Hell on Wheels Rodman's Avatar
    May 2012
    CT
    Subscribed.. I am running Cobb S1 93. If I have some time after work Ill do a 3rd gear pull
    so you can compare.
    Rod
    2014 WRX SWP Premium sedan
    Stink-Eye Mob #57
    "Just remember, with great power comes great responsibility" - rarrior
  8. #36
    Apr 2012
    NW Suburbs, Chicago
    Thanks, I appreciate it.
  9. #37
    May 2012
    CT
    Here is a link to the 3rd gear wot log..
    https://docs.google.com/spreadsheet/...Xc&usp=sharing
    Rod
    Stink-Eye Mob #57
  10. #38
    Apr 2012
    NW Suburbs, Chicago
    Quote Originally Posted by Rodman View Post
    +1 Thanks for the datalog. I hope you don't mind that I graphed and posted your boost vs. RPM on a thread here for comparison purposes. My curve is similar to yours except that you have a spike to 16.5 which I was expecting to see on mine actually. I'm going to do a few more datalogs to see if I see anything different.
  11. #39
    Nov 2013
    Just got back from the dealer. The issue was the intercooler boot came loose because it was not properly installed at the factory.
    Yep...he did... I hate that dealership, it's were I got my car and had nothing but problems with them
    Sorry to bring up an old topic (especially one unfortunate as this), but 3 days ago I started hearing the same exact noise coming from my car.
    This morning I took my '13 WRX to my dealer and they report that my car is perfectly normal and that the noise I'm hearing is expected.
    Interesting.
    4 days ago it sounded MUCH quieter. I guess cars like to make noise after a certain amount of time?
    naked_dave1, do you know exactly where the intercooler boot is? I'd like to take a look at mine to see if I'm having the same problem, but I'm not sure where it is.
  12. #40
    Registered User Jboulay's Avatar
    Aug 2014
    I just had this same type of noise happen to my 2014. It happened after I launched the wrx. I have stock intake with Cobb stage 2 it sounds like I have an aftermarket In take now. No loss of power though or anything else wrong.
    2014 WRB WRX
    SPT Catback Exhaust, Cobb Shift Knob, AP v3 and Cobb Downpipe ordered and on the way
  13. #41
    Registered User blake866's Avatar
    Apr 2014
    Hey guys check out this video I made on how I fixed my boost leak in about 20 min.
