The whole thing is just poorly designed in my opinion. The glue holding the rubber gaskets (or sleeves) to the tube on either end apparently ends up breaking down. Once that happens the high flowing air essentially can get under the inside of the gasket and just pushes it out. The glue thing is what the tech told me at least when I asked for an explanation for this fairly prevalent problem in the GR's. The worm clamp seems to do it's job for a little but the gaskets are what seem to be the problem more than anything. They just find a way to help work the whole tube loose. Not to say that in this particular case it wasn't properly tightened, but having experienced it myself there's more than just a tight clamp that can make this tube fail. Some people have taken the gaskets completely off and used t-clamps to secure the hose which seems to be the best option other than aftermarket. The only problem with that, though, is that there's an increased possibility for denied warranty work if something would go wrong.
I had an 04 STi once and, if I recall, those rubber gaskets didn't exist. Does your '05? Tried to find a picture of it and this is the best I could do...
LinkBack URL
About LinkBacks
