Results 1 to 7 of 7
This is a discussion on smell of burning oil need help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey, so i have an 02 wrx i had the timing belt done a few months ago and the last ...
    May 2012
    hey, so i have an 02 wrx i had the timing belt done a few months ago and the last few days i have been noticing a burning oil smell. any thoughts???
    May 2012
    there are no visible leaks any where on the engine
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    did they replace the oil pump at the same time?
    May 2012
    no just timing belt and just the standard 105k mile maintenance
    May 2012
    not a noticeable amount. she is a little sluggish but i know that there is a good size boost leak that i need to fix
    Registered User powder's Avatar
    Aug 2006
    WA State
    My turbo oil seal began to leak around that time. Still haven't changed the turbo 90k miles later. Loses about 1 qt every 4k miles or so.
    Still, it's weird that you just noticed the smell after the timing belt was changed. Maybe they loosened a bolt on the oil pump on accident?
    Blobeye Syndicate #2004
    Military Militia #30-06
    2004 WRX - JBP:Stage 2:13.93 @ 96
    Wingless alas. Too bad it took a 50 ton truck to make it happen.
