Results 1 to 12 of 12
This is a discussion on Another rough running wrx within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Trying to help a buddy, 02 WRX rough idle, replaced plugs and they turn black immediately. compression varies from 95 ...
    Nov 2012
    Trying to help a buddy, 02 WRX rough idle, replaced plugs and they turn black immediately. compression varies from 95 to 140, did notice turbo intake ripped at clamp by turbo. Could this be issue? Anyway to test coils? They all create spark turning over with spark tester. Has 154,000 miles and not sure of history. Looking for some direction. Thanks
    Quote Originally Posted by late96 View Post
    This is a issue. There is another.
    That's an issue. I believe the service limit is 122 or something like that; in any case, it's higher than 90. That's a problem.
    You have low compression in a cyl. That sounds from here like a show stopper.
    Nov 2012
    Thanks, I will double check again tommorrow, doesn't look good according to your thoughts. Did'nt want to start throwing parts at it if it was done. thanks Brian
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    engine may be toast with jacked up compression. when you say varies.. do you mean between cyls? was it tested cold or warm? leakdown performed?
    Nov 2012
    I checked it warm, I will recheck tonight. Should it bee warm and how long should I crank? I was counting about 5 compression strokes per cyl. The 2 plugs on passanger bank will turn carbon black in 2-5 minutes of running, these if I recall were the lowest on compression. Thanks Brian
    Moderator Donkey's Avatar
    Da boonies
    Sounds like goners. Just make sure you hold the throttle plate open when you are doing the compression check. You only need 1 compression stroke. A leak down test might be able to tell you if it is valves or rings.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2012
    So warm or cold or does'nt matter? Thanks
    Da boonies
    You want to do it warm. Google search "compression test".
    2002 FORESTER S
    1998 FORESTER S
    Nov 2012
    Ok, ran car for like 5 minutes, copression test oassanger side 105 and 110 drivers side 150 and 155. Any suggestions? Thanks Brian
    Find out why two cyls have lower compression than the service limit whereas the other two are seem in great shape. At this point see what you're willing to do as far as digging. A leakdown isn't too much hassle and might tell you if it's top end or not.
    Nov 2012
    Just finished leakdown. Front passenger side 10% and rear passenger side 28%. Now what
    Apr 2007
    8000' up in Colorado
    Sounds like your rings are toast on the passenger side. It could be the valves too, but my money's on the rings. Time to either rebuild the engine or buy a new one.
    Scott
